Thumbnail Cache - Clear and Reset
Page 2 of 6 FirstFirst 1234 ... LastLast
  1. Posts : 72,050
    Jeff, I wish I knew for you. Please post back how it went for you. :)
  2. Posts : 161
    Hey Brink thanks for the tutorial.
    I've had this problem from long ago since Vista: from time to time (very random) my thumbnail cache resets and is kinda annoying to reload every photo and video again... is this normal?
    thx in advance.
  3. Posts : 72,050
       #12
    Hello Rick,
    While there is no limit on the thumbnail cache in Windows 7, I suppose that if it was a very large photo and video collection in that folder it may cause it to choke out and lag on you. As a workaround, you might see if separating some of them into smaller groups of photos and videos in different subfolders (ex: for different categories) may help.
  4. Posts : 161
    Brink said:
    Hello Rick,
    Thanks Brink, ill put them in separate folders and clear the cache just in case... ill keep you update of any changes...
  5. Posts : 161
    Hey Brink, i do as u told me and so far things where good till this morning when i check my pictures folder the thumbnails are rebuilding again, so i went to clean the thumbnails to check the size and it shows only 4MB so i do not clear it and went to videos folder same thing (rebuilding), so after it finish went to disk clean up again to check the size and its bigger so i think if it is a choke out and lag thing (only checking category folders no the actual files, 44 folders inside pictures 4 folders in videos) why to rebuild the whole thing?, what do you think? btw if i need to post this in another section (cause after all this isn't related 'bout ur tut) pls let me know, thx.
  6. Posts : 1,113
    windows 7 professional & ultimate 64bit laptops
       #15
    try the attached
    Icon Cache - Rebuild
  7. Posts : 161
    pacinitaly said:
    try the attached
    thx pacinitaly, this is like deleting the thumbnail cache but in a .bat right?
    ok now i just have to w8 and see if it happens again...
  8. Posts : 1,113
       #17
    they just get re built, but CURRENT
  9. Posts : 161
    thx for the info, i just run it and all seems like before (the thumbnails that where created still there and the ones i haven't checked it yet are rebuilding) do i need to restart the pc?
  10. Posts : 72,050
       #19
    Yes, you will need to Log off and log on, or restart the computer to rebuild the icon cache afterwards.
