How to Allow or Prevent Window Animations in Vista, Windows 7, and Windows 8
This tutorial will show you how to allow or prevent window animations such as restoring, minimizing, and maximizing windows for all or specific users in Vista, Windows 7, and Windows 8.
You must be logged in as an administrator to be able to do this tutorial.
EXAMPLE: Animations in Visual Effects Settings
NOTE: This is an example of the animations that will be affected no matter how it is set in the Visual Effect settings.
OPTION ONE
To Allow or Prevent Windows Animations using a REG File
1. Do
step 2 or 3 below for what you would like to do.
2. To Allow Window Animations
A) Click/tap on the Download button below to download the file below, and go to
step 4 below.
Allow_Window_Animations.reg
3. To Prevent Window Animations
step 4 below.
Prevent_Window_Animations.reg
4. Save the .reg file to your desktop.
5. Double click/tap on the downloaded .reg file to merge it.
6. If prompted, click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK to approve the merge.
7. Log off and log on, or restart the computer to apply.
8. When done, you can delete the downloaded .reg file if you would like.
OPTION TWO
To Allow or Prevent Windows Animations Group Policy
1. Open the
all users,
specific users or groups, or
all users except administrators Local Group Policy Editor for how you want this policy applied.
2. In the left pane, click/tap on the arrow to expand
User Configuration,
Administrative Templates,
Windows Components, then click/tap on
Desktop Window Manager. (see screenshot below)
3. In the right pane of
Desktop Window Manager, double click/tap on
Do not allow window animations to edit it, and do
step 4 or 5 below for what you would like to do. (see screenshot above)
4. To Allow Window Animations
A) Select (dot) Not Configured or Disabled, and go to step 6 below. (see screenshot below step 6)
5. To Prevent Window Animations
A) Select (dot) Enabled, and go to step 6 below. (see screenshot below step 6)
6. Click/tap on
OK. (see screenshot below)
7. Close the Local Group Policy Editor. (see screenshot below step 2)
8. Log off and log on, or restart the computer to apply.
