#70
Need4steer,
It may be related to your other post from the link below since it's not a elevated command prompt in your screenshots.
Elevated Command Prompt
Need4steer,
Thanks for your fast response.
Do you think that one or more of my actions should have done in an elevated mode?
If so, don't you think I should have getting some message or indication saying so?
Well, the problem is that you disabled UAC. Usually it will work perfectly fine running elevated items like this, but every once in a while you may get one that just will not run properly unless UAC is enabled and you have allowed it to run elevated. It would be worth a try to enabled UAC for now, then try again to see how it goes.
Thanks a lot.
I'll try it and will post back.
Hello Brink! Love this thread, as it has recently become relevant due to a game requiring an NTFS format external over a FAT32 format.
So. I've followed your tutorial exactly, and attempted this both in an elevated command prompt and on a safe mode with command prompt boot. Both times, I reach the following result:
"The conversion failed.
E: was not converted to NTFS."
I'm not sure where to go from here, without any errors given. Any advice on what to check? I can't afford to format my E: completely, as it carries most of my important files.
Edit: I realized my UAC was off and turned it to its highest settings, gave another attempt. No dice there either.
Hello Asura,
You might see if running the chkdsk E: /F /R /X command on the drive may help if it had any bad sectors causing the failure. Afterwards, try converting it to NTFS again.
Just ran through the command, no problems were found by chkdsk.
Took a LONG time.
Regardless, still receive that the conversion failed and E: was not converted to NTFS.
You might give the free program Partition Manager (Home Edition) a try to see if it may be able to convert it for you instead.
Downloaded the program, gave it a run through. I let it run into the option to "close" comes up after converting file system runs for a while, but no actual conversion happens. not sure if I'm using the program wrong in some form, or if it is just failing, though I suspect the latter since it seems to be just running the command prompt lines.
Well now that I know that I ran it in elevated mode (note 1) it seems that my DOK is problematic - I cant format it only to exfat unless I'm using a 3'rd party utility.
(note 1) - https://www.sevenforums.com/1037016-post10.html
I think I would start over with removing all the data on the disk. I'll do so with the "clean all" command via diskpart. Look at this great tutorial, also from Brink - Disk - Clean and Clean All with Diskpart Command
Please note that if you have any information on volume e: you must backup it before performing the "clean all" command!.
BTW you wrote that this subject became relevant due to a game requiring an NTFS format external over a FAT32 format. How come? Do you want to copy it's installation image which size is larger than 4GB?
