Convert FAT or FAT32 Volume to NTFS
Page 11 of 17 FirstFirst ... 910111213 ... LastLast
  1. Posts : 12
    Windows 7 Home Premium 64-bit
       #100
    Thank you for the awesome tutorial! I got my external hard drive converted to NTFS pretty smoothly, except for getting that inconsistency error. Keep up the good work!!
  2. Posts : 72,052
       #101
    That's great news Pimiimip. You're most welcome. :)
  3. Posts : 2
    Windows 7 (64-bit)
       #102
    How Long?
    How long of a process is this, normally? My 8GB cruzer has been running for HOURS but I don't want to stop it in fear of bricking the drive...
  4. Posts : 2,009
    Windows 7 Ultimate x86
       #103
    8GB ??? No idea but my 1TB external Hard drive was done in less than 10 minutes
  5. Posts : 72,052
       #104
    Hello Sean, and welcome to Seven Forums.
    A USB flash drive would be slower than a internal HDD since it is connect via USB, but that is a long time for even that. Was the USB drive encrypted or compressed? If so, that would take a while for it to finish.
  6. Posts : 2
    Windows 7 (64-bit)
       #105
    No, there was no encryption or compression on the drive. I got fed up with waiting so I closed the command prompt and, luckily, the disk management screen showed NTFS!
  7. Posts : 72,052
       #106
    That's great news.
  8. Posts : 1
    Windows 7 Ultimate 32bit
       #107
    omg!!! you know what it worked .. thank you so much... that thing was a pain in my arse, i wasn't able to copy huge files in my hdd.. but you made it possible. thank you ...
    ps: it took ten mins to convert 500gb hdd with 435gb of data.. :P
  9. Posts : 72,052
       #108
    You're welcome Pwner, and welcome to Seven Forums. Thank you for posting back your results. :)
  10. Posts : 3
    xp
       #109
    Apologies for dragging up an old thread but found it on google and it seems an appropriate place for my question/problem. I used convert.exe to convert a 1TB external drive from fat32 to ntfs, had no problems or errors and had a message in the command prompt stating that the conversion had completed. However when I select the drive in my computer or using the drive management utility it still states that the format is FAT32. Any ideas?
