Downloads Library - Create
  1. Posts : 72,061
    Harry,
    You would want to left click on the Download button above, then click on Save if available instead of right clicking it.
  2. Posts : 20
    Windows 7 (7600)
    Thanks! Bumped into some problems, but I think I didn't read it properly.
    Works like a charm :)
  3. Posts : 72,061
       #12
    You're welcome Ensi. If you can remember what problems you ran into, then please post back with them so that I can update the tutorial to hopefully help others avoid the same problems that you had. :)
  4. Posts : 3
    Win7
    Thanks again Brink. Finally got it when I changed my download location in the browesr. Not sure why it was set to download to a non-existent drive but all is fine now. Thanks again.
    Harry
  5. Posts : 72,061
       #14
    Ah, that's great news Harry. I had thought you were using Internet Explorer. That would explain that. :)
  6. Posts : 34
       #15
    Worked for me. Thanks (again!)
  7. Posts : 72,061
       #16
    You're most welcome DjProDG. :)
  8. Posts : 8
    Se7en
       #17
    First of all thanks for tut awsome second... Sorry for my english.
    I got a question... How to get the default icon for Downloads? I got ony normal directory because i have deleted desktop.ini for the directrory...
    And second Where i need to paste location of libery icon?
  9. Posts : 72,061
       #18
    Hello Aazmath, and welcome to Seven Forums.
    You can click on the blue "Download" button below step 1A to get the Download.ico file in a ZIP file. I'm not sure what you mean, but clicking on the link will help show you where to create the Library file at for this.
  10. NoN
       #19
    Thanks Brink for that Icon...
    I was wondering if i can easily change the Workstation Library Icon, instead of the one c:\users\Downloads...
    I have only change the C:\users\public\downloads with the icon you have put on here...
    Is it possible to have somewhere the recorded TV icon the we can find inside the system32 "imageres.dll" for doing the same apply inside the Workstation Library (i case i'm creating a new Library)?
    Or how do i extract it? I mean I want the Icon 256x256...to be in a dedicated folder...
    Thanks!
