Media Center- Setup Movie Library
Page 18 of 18 FirstFirst ... 8161718
  1. Posts : 1
    Thank you for the tutorial and comments. Was working through 1TB manually and have several more to go. Made it so much easier.
  2. Posts : 1
    Destructive batch file? (file2folder.zip)
    I ran the batch file on the drive where all my movies are located. After I did, I started getting missing .dll files for most of my programs (Windows 7). I had to restore my drive using my last backup. Why did this happen?
  3. Posts : 1
    Windows 7 Professional 32 bit Service Pack 1
       #172
    Windows 7 Tutorial: Media Center-Setup movie Library
    Thank you. I have profound troubles with my Media. all the information has helped patch it up.
  4. Posts : 1
    Didnt work
    Okay, I was so excited about getting my movies in order and information set but at last it didn't work for me. So maybe i am slow and didn't follow the directions right(some i didn't quite understand). so the part about finding files and putting them in a folder.jpeg is confusing. Where do I put the folder? I have download 344 jpeg files for each movie. I have tried putting each one in the movie folder its for and also in just one group file. Neither has work when I loaded them in my windows media player. Any help would be appreciated. Thanks
