#20
yes ok. Well, it's not a very serious problem. I think I just survive without it.
Yeah, that's the only downfall with libraries and all included folders sharing the same folder view.
This is one of the most frustrating areas of Windows 7. Windows Explorer offers many possibilities to play with the way it shows things (and I'm using on purpose the most un-Microsoft and non-specific way of saying it), but when it comes to customizing it in a consistent way, all across one's folders, the logic of the beast is ridiculously complicated to grasp, and controls are all over the place.
To give an example of this user-hostile programming, here is what you had to write on a related thread :
That's the sort of thing that drives me mad... I have been hopping from one related thread to another through links for quite a while now, and I still cannot get the big picture.If Apply to Folders was used to set folder views and templates, then this tutorial will not reset them to default since "Apply to Folders" makes what you set the new default. Instead, you will need to use Reset Folders to be able to reset each folder template back to default.
Do you think it might be possible to merge some of those tutorials into a larger one, in order to shed light on Microsoft's "logic" ? Maybe it has already been done and I haven't found it ?
One of my pet peeves is the way the option to hide or unhide file extensions is buried deep inside the menus. Now I know how to do that, but it should be brought back right in front. I find myself constantly needing to switch from one state to another. Changing from large icons to small icons, not so much.
Hello Clairvaux, :)
Please explain what you are wanting to do, and we may be able to come up with a solution for you.
[SIZE="5"]Hi there Sir;
uhhmm, i don't really know how this work or if im in the right direction, but i've a question;
Can anybody please be so kind to tell HOW DO I ADD THE BITRATE IN ONE GO TO ALL FOLDERS IN WINDOWS 7???
Ive a huge collection of music files for my hobby & work at the same time, but everytime i go into a folder of sub folders, ive to manually add the bit rate (its a pain), like i wanna see the track with 320 or 128 bit rate, but i can seems to find that out, been google it for awhile and google always send me to your forum, (sorry im kinda new to this)
Hello Malonibiza, and welcome to Seven Forums. :)
Double check using step 1 to make sure that the folder template is set to "Music" with the "Also apply this template to all subfolders".
Afterwards, do the rest of the steps in the tutorial to set the folder view how you want with the bit rate column, then use "Apply to folders" to have it applied to all folders using the "Music" template.
Hi there mr. Brink, ok thnx U, im gona tried that and ill get back to You, whether it works yes or no:)
Thank you kindly for your time,,,
Marlon
Hahahahahah, Mr. Brink you're a genius,, i owe you BIG time,, if we ever come across, ill buy You 10 drinks, swear, BIG THANK YOU AND A LOT OF GOD BLESSING TO YOU;;;))))))
Ohh another thing, how do i change my profile pic??
Thank you kindly; i'm not gonna even sleep tonight;))
