SSD Alignment
Page 2 of 14 FirstFirst 123412 ... LastLast
  1. Posts : 16,149
    7 X64
    The Paragon program did a perfect job.
    It rightly told you the alignment is already correct.
      My Computers
  2. whs
    If the 100MB partition is aligned correctly, then the next partition (C) is aligned correctly.
  3. Posts : 16,149
    7 X64
       #12
    Not sure why he wanted a refund on a program that did a perfect job
      My Computers
  4. whs
    I guess he found out that he did not need it - with that program, LOL.
  5. Posts : 968
    He wanted to get the job done then wanted his money back cause he didn't need it anymore...ha...I just used diskpart to do mine and it was very easy and effective plus it's free......
  6. Posts : 6
    Windows 7 Professional
       #15
    Am I OK after 1st partition?
    Thanks everyone for this thread. I'd like to ask a clarifying question:
    I used Acronis TrueImage to clone my old HDD onto an SSD for my Dell laptop. It placed the first partition (78 MB "OEM") and put that at offset 31 kB, which of course is not evenly divisible by four.
    However, all other partitions start in the MB or GB range, all of which will be divisible by four. So, does that mean that I may have minor issues with that first "OEM" partition, whatever that does, but my main C: partition (partition 3 at offset 180MB) is OK? Thanks!
  7. whs
       #16
    You are OK. You probably hardly ever have to access this OEM partition, and if you do, it is not going to make a world of difference.
  8. whs
       #17
    Today I got a new Mushkin 60GB SSD. I am not yet sure what I will do with it. All my PCs have SSDs already. I bought it because $69.95 was an intriguing price.
    In order to be able to do anything with it, I defined a primary active partition with Disk Management on it. To my surprise, Disk Management made a perfect 1024 alignment. So no need to do it with Diskpart any more.
  9. Posts : 16,149
    7 X64
       #18
    Yes diskmgmt has always done that, since Vista anyway.
      My Computers
  10. whs
       #19
    I never knew that because I always used Diskpart.
