#110
We have answers, and whs has some of the best ones.
I've just used the paragon alignment tool 4.0 to align my SSD (OCZ Vector 128GB), and the problem is "blue screen of death" appear when windows 7 restart to align my drive.
Anybody help me @@!
You must have made a little mistake somewhere along the line because the program does work. You can try the AOMEI Partition Assistent instead - or do it the way I decribe it here.
OK man! I'll try AOMEI Partition Assistent free first.
One more question, after aligned my ssd successfully, may "31k bad-error" will fixed?
Hey guy!
I used AOMEI Partition Assistent free vesion to align my ssd. After win 7 restart to align, the process bar is 3,33% and mornitor turn to black, i waited for 15m and nothing happen, so i have to shutdown my pc (hold power button in 5s).
After that, i turn on my pc and the error appear:
"Windows Boot Manager:
Windows failed to start. A recent hardware of software change might be the cause. To fix the problem:
1.Insert your Windows installation disc and restart the computer.
2.Choose your language settings, and then click "Next".
3.Click "Repair your computer."
If you do not have this disc, contact your system administrator or computer manufacturer for assistance.
Status: 0xc000000f
Info: The boot selection failed because a required device is inaccessible"
Now i've just fixed this error and access my pc normally.
What's problem with "AOMEI Partition Assistent free vesion" and my PC. @@!
P/S: Sorry about my bad english
Before i come to this topic, i format my ssd and make a clean install win7, my pc works normally. But my ssd has been " 31k bad-error" when i benchmark it (using as ssd benchmark software). Somebody told me try to align my ssd to fix this error:
[YOU************//www.youtube.com/watch?v=wW7KWqWcLe0[/YOUTUBE]
Apparently the AOMEI program is faulty. That does not really amaze me because their Imaging program is buggy too. It does not work at all on 32bit systems. You are probably best off to do what John suggests.
