Recent Search Box Suggestions - Enable or Disable
    How to Enable or Disable Windows 7 Explorer Recent Search Box Suggestions
    This will show you how to enable or disable Windows Explorer in Windows 7 from displaying recent search entry suggestions as users type into the Search Box. By default, search box suggestions is enabled in Windows 7.
    These suggestions are based on the user's past entries into the Search Box.
    EXAMPLE: Recent Search Box Suggestions Enabled and Disabled Recent Search Box Suggestions - Enable or Disable-example2.jpg
    OPTION ONE
    Using a REG File Download
    1. To Enable Recent Search Box Suggestions
    A) Click on the Download button below to download the file below
    Enable_Recent_Search_Box_Suggestions.zip
    B) Go to step 4.
    2. To Disable Recent Search Box Suggestions
    Disable_Recent_Search_Box_Suggestions.zip
    B) Go to step 4.
    3. Click on Save, and save the .zip file to the desktop.
    4. Open the downloaded .zip file and extract the .reg file to the desktop.
    5. Right click on the extracted .reg file and click on Merge.
    6. Click on Run, Yes, Yes, and OK when prompted.
    7. Close and reopen the Windows Explorer window to apply if opened.
    8. When done, you can delete the downloaded .reg and .zip files if you like.
    OPTION TWO
    Through Local Group Policy Editor
    2. In the left pane, click on the arrow to expand User Configuration, Administrative Templates, Windows Components, then click on Windows Explorer. (See screenshot below)
    3. In the right pane, right click on Turn off display of recent search entries in the Windows Explorer search box and click on Edit. (See screenshot above)
    4. To Enable Recent Search Box Suggestions
    A) Select (dot) Not Configured or Disabled. (See screenshot below step 6)
    B) Go to step 6.
    5. To Disable Recent Search Box Suggestions
    A) Select (dot) Enabled. (See screenshot below step 6)
    6. Click on OK. (See screenshot below)
    7. Close the Local Group Policy Editor. (See screenshot below step 2)
  1. Posts : 18,404
    Ooh,
    this one will come in handy. Thanks Shawn!
  2. Posts : 72,051
    You're welcome Aaron. :)
  3. Posts : 194
    Windows 7 RTM x86
    This is what I was looking for .. Thank you Brink.
    One more question pls : How to stop the search when I get my file ? When I click on the cross button (Side of Search ) ,my results page goes away.This was not the case with XP. Please help
  4. Posts : 72,051
    You can stop the search in progress by clicking on the refresh swirl arrows (boxed in red below) at the right of the address bar. :)
  5. Posts : 194
    Windows 7 RTM x86
    Oh Thank you once's again Brink
  6. Posts : 72,051
    You're welcome.
  7. Posts : 18,404
    Hey Shawn,
    if you want to clear the list instead of disabling saved searches, you can go here HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\WordWheelQuery and delete WordWheelQuery from the left pane. It will rebuild itself once you have entered search entries again. Or you could delete individual entries, by hovering over them on the drop down list with the mouse and hitting the Delete key.
  8. Posts : 72,051
    Thank you Aaron. I have bookmarked this one. It will make a good separate tutorial for a option to edit them for those that do not want to disable them. :)
    The option to delete them in the search list in Windows Explorer is grayed out for me, but you can delete the individually in the registry as well. If you click on modify for one of the numbered items in the registry, you will see the search item in the middle of that long binary number.
  9. Posts : 18,404
    Hi Shawn,
    You're saying the option here to hover over them and press delete is greyed out? Maybe from having the search suggestions disabled it does that?
