Fonts - Install
Page 2 of 6 FirstFirst 1234 ... LastLast
  1. Posts : 2,899
    weird as i have x64 on and it show it like i showed in the screenshot....
    can you open cmd
    cd into the directory "cd %WinDir%\fonts" where
    and type "dir"
    idk but the thing is that are font groups as you can see in my there are arial bold, italic ect and that is why there are alot more than is shown....
    its wierd though as i did not do any config changes other than the ones that i said...
    another would be "hide protected system files" have it unchecked and check again...
    this will output every file in the fonts folder...
  2. Posts : 18,404
    That is weird. I have this many with x64. I have show hidden files and I checked show hidden protected OS system files on and off and logged off and back on. Made no difference..
  3. Posts : 66
    Windows 7 Ultimate 64x
       #12
    Brink said:
    You're welcome Windows 7. It did turn out pretty easy.
    Easy enough to not need to read a tutorial on how to do it.
  4. Posts : 26
    Windows XP Pro SP3 / Windows 7RC 7100
    I have made sure that the fonts are not hidden. And after looking at garysgold screen shot, I have exactly the same icons appearing.
  5. Posts : 3,141
       #14
    darkassain said:
    can you open cmd
    and type "dir"
    The fonts are there, I can use them in all my programs. Just can't hide or unhide what I can't see.
    Hi SnapCount,
    Do you have any font handling software installed?
    Gary
  6. Posts : 26
       #15
    Crap.... I dont believe this... Just installed the RC on my desktop and low and behold... 10 fonts show up.... Go to my laptop and installed RC from the same DVD and guess what.... 201 fonts show up WTF!
    Hi garysgold,
    No, i dont have any font handling software. It seems to me like its for some strange reason - its hardware related. CRAPNESS
  7. Posts : 4,925
    Windows 7 Professional 64-bit
       #16
    I have 134 fonts listed.
  8. Posts : 93
    Windows 7 (Build 7068)
       #17
    You can also right click and go "Install." I did that in version 7100, so I can't verify if it works in previous builds.
  9. Posts : 17
    Windows Vista/Windows 7
       #18
    Thanks for nice description about installing new fonts to Windows 7
  10. Posts : 72,050
       #19
    You're welcome Chessian. :)
