Fonts - Install
Page 4 of 6 FirstFirst ... 23456 LastLast
  1. Posts : 4
    I tried to install them from the desktop and they wouldn't. My laptop is owned by my school-so you're saying I don't have administrative priviledges to add the fonts? I tried to do what you suggested and I can't make changes. That stinks! Thank you for all your help, if you have any other ideas, please let me know.
  2. Posts : 72,051
       #31
    Ah, if your user account is not an administrator type user account, then you will not be able to install fonts.
  3. Posts : 2
    Windows7 Home Premium 64 bit.
       #32
    Can't install ttf
    When I try to install a ttf that i downloaded it gives me this error message
    Can't install.....(name of the file) does not appear to be a valid font.
    I tried all of your recommendations to no avial.
    Any other suggestions.
    Cheers.
  4. Posts : 2
       #33
    Thanks will try that. Looks like my son has changed the account settings.
  5. Posts : 72,051
       #34
    Hello Axeman, and welcome to Seven Forums.
    Uh??
  6. Posts : 3
    Windows 7 Home Premium 32bit.
       #35
    Windows 7 Home Premium 32 Bit
    Could you please send me the downloadable defaut Fonts for Windows 7 Home Premium. It seems my current Fonts are corrupted due to some malware or otherwise.
  7. Posts : 72,051
       #36
    Hello Kanchanman, and welcome to Seven Forums.
    Sorry mate, that would just be to large of a file to be able to upload here.
    I would recommend to do a full scan of your system with MalwareBytes free to help make sure that your system is clean.
    Afterwards, you could see if running a sfc /scannow command may help. If not, then you could do a system restore using a restore point dated (if available) when they were fine.
  8. Posts : 3
       #37
    Thanks , I will try that for sure. BTW can the default font file be sent on my email ID?
  9. Posts : 72,051
       #38
    Kanchanman,
    Let's see what the results of the sfc /scannow are first. It may be able to fix them for you. If not, it will give you a list using OPTION THREE in that tutorial for which ones that need to be replaced. :)
  10. Posts : 3
       #39
    I did 1st & 2nd option. It says all ok!
    I had already used the restore point option and do not have an adequate resore point created when the fonts were "okay"
