#40
Could you post a screenshot showing what is wrong with the fonts and saying what it should be to see if there may be something that we could help to fix?
Sir,my default fonts had gone so i cant to anything now.All of them are wingding?Can u give me zipped font that used by the system because i cannot download large file with my speed.
Hello PortgazHyde,
Sorry, but the size of that file for all the default fonts would just be way to big to upload.
If you have a restore point dated before this happened available, then you could do a system restore at boot with that restore point selected to undo and fix this issue.
The problem is i have no restore point because i deleted it earlier with CCleaner.I had downloaded Tahoma and it fix almost all the display.What i should download next to make my OS 100% readable?
Well, the problem is not just Windows itself, but everything (included and installed programs) that used the fonts that are now no longer there.
You might consider doing a repair install to add them all back if that's an option for you.
Sir, i cant repair install because im using laptop.
I searched for fonts but i got no fonts that helps.
Oh, do u got Arial Regular? My .NF keep requesting for it.
And my apps cannot be resize and the text is bigger.
I installed marlett but it didnt work.
PortgazHyde,
Here's a couple default fonts in a ZIP file below to install that may help some. If you need any more specific fonts, then please just let me know. :)
Installed the fonts and got no error but my application windows cannot fit the screen.
I somehow cannot fix it.
