Fonts - Install
Page 5 of 6 FirstFirst ... 3456 LastLast
  1. Posts : 72,052
       #40
    Could you post a screenshot showing what is wrong with the fonts and saying what it should be to see if there may be something that we could help to fix?
  2. Posts : 40
    Ultimate x32
       #41
    Upload please
    Sir,my default fonts had gone so i cant to anything now.All of them are wingding?Can u give me zipped font that used by the system because i cannot download large file with my speed.
  3. Posts : 72,052
       #42
    Hello PortgazHyde,
    Sorry, but the size of that file for all the default fonts would just be way to big to upload.
    If you have a restore point dated before this happened available, then you could do a system restore at boot with that restore point selected to undo and fix this issue.
  4. Posts : 40
    Ultimate x32
       #43
    Fixed some problem
    The problem is i have no restore point because i deleted it earlier with CCleaner.I had downloaded Tahoma and it fix almost all the display.What i should download next to make my OS 100% readable?
  5. Posts : 72,052
       #44
    Well, the problem is not just Windows itself, but everything (included and installed programs) that used the fonts that are now no longer there.
    You might consider doing a repair install to add them all back if that's an option for you.
  6. Posts : 40
    Ultimate x32
       #45
    Sir, i cant repair install because im using laptop.
    I searched for fonts but i got no fonts that helps.
    Oh, do u got Arial Regular? My .NF keep requesting for it.
    And my apps cannot be resize and the text is bigger.
    I installed marlett but it didnt work.
  7. Posts : 72,052
       #46
    PortgazHyde,
    Here's a couple default fonts in a ZIP file below to install that may help some. If you need any more specific fonts, then please just let me know. :)
    Fonts - Install Attached Files
  8. Posts : 40
    Ultimate x32
       #47
    Installed the fonts and got no error but my application windows cannot fit the screen.
    I somehow cannot fix it.
  9. Posts : 72,052
       #48
    Looks like you may need to consider doing a OEM factory restore of Windows 7.
  10. Posts : 72,052
       #49
