#40
Yep, I fully understand your question.
Brink , i want ask again, if we often do defrag maybe like a week once, that will damaged the Harddisk / decrease Harddisk Lifespan? simple said is "if often do disk defrag it will damaged the Harddisk?" Thanks :)
er I'm a little puzzled some people say don't defrag your recovery drive/ recovery partition ( D in my HP laptop ) and some say it's OK , look how much mine is fragmented
what should I do , is it OK to defrag my recovery drive ?
and just to add my C drive is fine I defrag that when ever it's needed but I've been fear-ful of de-fragging my recovery drive D
Hello Juxxize,
Usually it's not recommended to defrag the recovery partition. I would say let it be since if anything went wrong with it, you would no longer be able to do a factory recovery of Windows with it.
It's not going to hurt anything since you are not supposed to be using this partition for anything other that doing a factory recovery as needed.
If you have not already, I would also recommend to create a set of recovery discs or save a recovery image to a USB flash drive as a backup.
Hope this helps, :)
Thank-you Brink, i have a back-up and system image i made on an external hard-drive ( although it's about time i did a fresh back-up ) and i made a system repair disk a while back although i may make another just to be on the safe side . I've not heard of the Recovery Disc Creation/ Recovery Media Creation which is the second option mentioned in the page of the link you posted so i will look into that but having a repair, backup and system image i made along with the back-up i should be OK. It is odd my recovery drive has got so fragmented isn't it when it isn't used. I factory reset my laptop a few months ago but apart from that it's never used so it's odd indeed, thanks again.
