Thumbnail Previews - Enable or Disable
Page 2 of 9 FirstFirst 1234 ... LastLast
  1. Posts : 1,040
    XP MCE .... XP Pro 64 .... W7 U x64
    I was beginning to think I'm the only one who think it's Stupid to replace some, but not all, Icons on the desktop with Thumbnails.
    I've tried to track all the registry changes with all Thumbs disabled ...
    But I can't figure out which ones (if any) will turn off the thumbs on the desktop only.
  2. Posts : 72,072
    Hello Kremmen,
    I'm afraid that it's all or none.
  3. Posts : 4
    windows 7
       #12
    HulaLady said:
    I used to use Thumbnail Handler which automatically showed my Paint Shop Pro tubes (versus just a PSP icon), but have been unsuccessful locating a program that will do this. I found this site and downloaded both and installed both. Nothing worked, so I am wondering if I should delete the registry files that these downloads installed (thus my asking if anyone had the exact file name that I should delete).
    If anyone does have a PSP Thumbnail Handler that works with Windows 7 64 bit, for all versions of PSP, I would appreciate hearing back. Thank you Brink for your prompt response.
    I spent hours at this site, thank you so much for sharing your knowledge....
    Aloha all
    to view PSP files thumbnails just unzip this dll put it anywhere then run cmd goto where you put the file and run "regsvr32 psdcodec.dll"
    All done restart explorer and you will see thubnails
    Thumbnail Previews - Enable or Disable Attached Files
  4. Posts : 13
    Windows 7 Ultimate x86
    any way to disable thumbnail viewing on the folders only and show thumbnails for other files like pictures?
  5. Posts : 72,072
       #14
    Hello iFission,
    Sorry, but it's either a all or none setting.
  6. Posts : 14
    Windows 7 Home Premium
       #15
    Brink said:
    Hello iFission,
    I love my folder icon & don't want thumbnails over it.This sucks
    Attached Thumbnails Attached Thumbnails Thumbnail Previews - Enable or Disable-folder-image.png
  7. Posts : 72,072
       #16
    Hello Sam, and welcome to Seven Forums.
    You could disable thumbnail previews, then do OPTION ONE in the tutorial below to change the default folder icon with your icon above.
    How to Change the Windows 7 Default Folder Icon
  8. Posts : 14
       #17
    Hi Shawn,
    I have changed the folder icon. The thing is I don;t want thumbnails over the folder icon (saying which images are inide the folder). So I disable the thumbnails option but then I cannot see image thumbnails too unlike XP where only picture folder shown thumbnails over the folder which too can be cutomised . But as you said its all or none, which sucks
    Attached Thumbnails Attached Thumbnails Thumbnail Previews - Enable or Disable-desktop_-1-.jpg
  9. Posts : 1
    Windows 7 x64
       #18
    Is there a way to do what sam2O1O wants to do?
    I need it that way, to work just like XP.
    I don't understand how that option is not available :-S
  10. Posts : 72,072
       #19
    Hello Peikojose, and welcome to Seven Forums.
    You could use the tutorial below to change the default folder icon used by Windows 7 using Resource Hacker. This way you can leave thumbnail previews turned on if you like to see thumbnails of files, but not have them for the folders.
    Folder Icon - Change Default Icon
