Fonts - Change
Page 11 of 16 FirstFirst ... 910111213 ... LastLast
  1. Posts : 168
    Windows 10 Home 64b
       #100
    Wow it worked :), i freed some space without a mess. The only problem was with the browsers (IE and Firefox) opening, but with everything in black and screwed up. Fixed it after installed the Arial fonts, so beware people, don't delete the Arials.
  2. Posts : 72,050
       #101
    That's great news LM.
  3. Posts : 168
    Windows 10 Home 64b
       #102
    I checked the Fonts folder with the command prompt and there are a lot of fonts that are not visible in the folder and they are not in the registry, cab i delete them? how to uncover them? check attachment.
  4. Posts : 72,050
       #103
    LM,
    It may be best to leave the ones that are not listed in the Fonts folder or registry alone.
  5. Posts : 168
    Windows 10 Home 64b
       #104
    Took the risk and deleted some but from the command prompt when using the Windows 7recovery option, is working good for now, but i don't encourage anyone to do it though. I don't know if it have to do with it, but now is using 1.03GB of mem, when the normal was 1.8 and up in my system.
  6. Posts : 72,050
       #105
    Good deal. :)
  7. Posts : 5
    Windows 7 x86 Ultimate
       #106
    Brink said:
    Hello Fixer, and welcome to Seven Forums.
    To change the font size of an item not listed in OPTION ONE, you could use a 3rd party skinning program to make it easy to do so.
    So, what software exactly did you mean?
  8. Posts : 72,050
       #107
    Fixer,
    A program like the one Dennis posted above. You could also use something like WindowBlinds, but it's not free. There's all sorts of these type of programs available. You'll just need to see if they include the feature to change fonts as well, and try them out to see how you like it before buying it if it's not free.
  9. Posts : 3,302
       #108
    Hello
    I used the reg download and amended it to the font I wanted.It applied fine however when I go to personalize\window colour\advanced for some fine tuning the font entry is always empty.I can change to bold or italic just concerned the drop box is empty and not showing the font i chose.
    Danny
  10. Posts : 72,050
       #109
    Hello Danny,
    I have not seen that before. Did you delete any fonts?
