Fonts - Change
Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
  1. Posts : 3,302
       #110
    No havent deleted or added any fonts at all.There all the original ones.It gets worse i created some reg files for some other fonts and the personalize screen becomes over large with no scroll bar to get to the bold or italic boxes
    Danny
  2. Posts : 72,052
       #111
    What font did you use to set as the default one in the tutorial?
    I would recommend to restore the default font back for now.
  3. Posts : 3,302
       #112
    Ive tried a few now just by altering the font name with notepad using your script and saving as a reg file.The ones that cause this issue (for me anyway)are impact,calibri , Saego print and a few others also on a few the font hasnt changed at all.Odd.
    Restored back to default with no problems though
    Danny
  4. Posts : 56
    Windows 7 Ultimate
       #113
    Another great tutorial mate, can we change the default font of windows installation?
    I have already tried with restorator but not working for me, if you can help me.
  5. Posts : 72,052
       #114
    Hello niceguy,
    What font location do you mean by "windows installation"??
    If you mean while installing Windows 7, then not that I know.
  6. Posts : 56
    Windows 7 Ultimate
       #115
    Brink said:
    Hello niceguy,
    I am talking about all the font style which we see during the entire installation process.
    Like "Setup is starting", "Setup is copying temporary files", etc
    I know the location and I did try to change the font as well with restorator but when I test my OS the font are still default one only.
  7. Posts : 72,052
       #116
    I'm not sure if it's possible that they can be changed, or easily if so, since they are loaded from the installation disc itself. This might be something to post as a new thread in the Customization forum area to see if someone may happen to know how.
  8. Posts : 119
    Windows 7 Ultimate
       #117
    Does this work for the Windows 7 Setup Screens?? John
  9. Posts : 72,052
       #118
    Hello RBCC,
    No, just inside Windows 7 after it's installed.
  10. Posts : 3
    Windows 7 64bit
       #119
    It comes up like this. What should I do ?
    Thanks.
