Fonts - Change
Page 14 of 16 FirstFirst ... 41213141516 LastLast
  1. Posts : 72,062
       #130
    Hello Impedator, and welcome to Seven Forums.
    What option did you use to change the fonts with?
    If OPTION TWO or THREE, and the restore REG file in step 3 of OPTION THREE didn't help, then you might consider doing a system restore using a restore point dated before you changed the fonts to undo them.
    Hope this helps for now,
  2. Posts : 1
    windows 7 ultimate
       #131
    impedator said:
    Hello Brink,
    Great tutorial, but I still have some problem with Win7 fonts. See my attachement, fonts in Outlook account setting is realy ugly, how can I reset this font to default?
    I had exactly the same problem. To what reason ever tahoma standard and tahoma bold were deleted by "something?". Copy them from another pc and install them on the pc where you have the problem. Everything is fine again.
    BR
    Juro
  3. MHM
    Windows 7 Ultimate 32bit
       #132
    Hi Brink thanks for information that is very useful I want know how can I change this font Fonts - Change-name2.jpg could you help me?
    I use my os in persion language but this font is too crazy
  4. Posts : 72,062
       #133
    Hello MHM, and welcome to Seven Forums.
    What font were you wanting to use from your C:\Windows\Fonts folder instead?
  5. MHM
       #134
    Thanks Guys
    The font name is nazanin. I do not know heard abut that..!
    So have an advice?
    the file taype is .ttf I change that to ".txt" for upload
    Attachment 206302
  6. Posts : 72,062
       #135
    If Nazanin is the exact name of the font as it appears in the C:\Windows\Fonts folder, then you could use OPTION ONE or OPTION TWO to change the fonts to it.
    I'm not sure if it will be the same for you in OPTION THREE since you do not have an English copy of Windows 7 though.
  7. MHM
       #136
    The exact name of the font is "2 nazanin regular" you know this font make me hank I want run from it
    1. I use the "LIP farsi" to change os language and do not have problem to reinstall the system os
    Try the way you say
    2. if you mean if I do the option that you give me I lose the english world..!! I will find another font!!
  8. Posts : 8
    Windows 7 Ultimate 32-bit
       #137
    Thanks for this!
  9. Posts : 72,062
       #138
    Welcome to Seven Forums Bigpump. :)
  10. Posts : 6
    i have used this tutorial but it doesnt effect on title and desktop icons
    what should o do ?
