Fonts - Change
Page 16 of 16 FirstFirst ... 6141516
  1. Posts : 4
    Windows 7 Pro 32 bit
       #150
    I have uploaded a screenshot of part of a SevenForum webpage showing the "Hand with a pen"
    Before I changed the font I got a "Tick" symbol just like in your screenshot.
    Attached Thumbnails Attached Thumbnails Fonts - Change-screen-shot-10-04-14-05.33-pm.jpg
  2. Posts : 72,062
       #151
    Ah, I see what you mean now. I get the same in Internet Explorer instead of Windows Explorer.
    I'll have to look into this more to see what may be causing it since I don't see anything obvious for why.
  3. Posts : 72,062
       #152
    Ok. I found the culprit. It was changing the font below that caused it. Please try the new .reg download in the tutorial to see how it works for you now. :)
    "Segoe UI Symbol (TrueType)"=""
  4. Posts : 4
       #153
    That works great, thanks very much for fixing it, it should have been obvious to me as well "Symbol" is a bit of a give away.
    Its amazing nobody has noticed that since your original post back in 2008.
  5. Posts : 72,062
       #154
    You're most welcome.
    Those were my thoughts as well, but just didn't click back then for some reason.
  6. Posts : 19
    windows 7 proffesional x64
       #155
    How can I change the fonts in control panel and in the command module?
  7. Posts : 72,062
       #156
    Hello Giova, :)
    OPTION THREE should change the font for all Windows dialogs.
    The command prompt wouldn't be included since it's a separate program, but you can use the tutorial below to do so though.
    Command Prompt - Personalize
  8. Posts : 12
    Windows 7 Professional 64-bit
       #157
    Brink said:
    Hello Coldout,
    What text location on the desktop has not changed?
    Hey Shawn, quoting only to mention you. I need to change both the font and size used everywhere including control panel and its applets. The font size in those places seems to be hardcoded but I reckon there was a way using third party software. Do you know?
  9. Posts : 72,062
       #158
    Hello mate,
    I posted something below in your original thread for this that will hopefully help.
    How to change the system font and size globally in all dialogs
