Fonts - Change
Page 5 of 16 FirstFirst ... 3456715 ... LastLast
  1. Posts : 4
    Windows 7 Home Premium 64 bit
       #40
    Ugly fuzzy fonts
    I just can't find a way to change the fonts on certain things.....like file lists, or the addressbar path when I go to a particular file. The same font seems to be used by Eudora to list the names of the mail folders, so it is probably a windows system font.
    I've downloaded the latest NVIDIA drivers for Windows 7, and tweaked all the font settings I could find.
    I've just uploaded some screenshots to show what I'm talking about.
    Can someone please assist?
    Attached Thumbnails Attached Thumbnails Fonts - Change-hardtoread.jpg   Fonts - Change-eudorafont.jpg   Fonts - Change-addressbar.jpg
  2. Posts : 71,959
       #41
    Hello Zanestein, and welcome to Seven Forums.
    Other than using some 3rd party skinning program like "Windows Blinds", the only options are the ones in the tutorial on the first page that I know of.
  3. Posts : 4
       #42
    If I knew exactly which font was being called, I could try to find where it was set and change it. Probably another registry entry.
  4. Posts : 2
    w 7
       #43
    stubborn fonts
    following option 2 i changed both to arial. and set default to arial too.
    still some buttons and fields showed font called mingliu:
    -on startup when asking to log in
    -programs like notebook, ff ...
    so in regedit-fonts i changed the data of that font to arial. and now arial pretends to be mingliu.
    It worked, i have arial everywhere now. but I think it might slow things down when i have it set up like that.
    i would like to know why the system is using mingliu and where to change it.
    thanks
  5. Posts : 71,959
       #44
    Hello Sodance, and welcome to Seven Forums.
    Yeah, unfortunately not all of the fonts can be changed without using a 3rd party skinning program (ex: WindowsBlind). A program will usually always use it's own set of fonts instead.
  6. Posts : 2
    w 7
       #45
    ok, thanks brink.
  7. Posts : 321
    Windows 7 Home Premium SP1 64-bit
       #46
    Hello Shawn, is it also possible to change the User Logon Fonts ?
  8. Posts : 71,959
       #47
    Hello Edrik,
    Not sure about how to change the fonts for that, but you can change the shadowing around the log on text.
    Log On Screen Text Shadow - Change
  9. Posts : 1
    windows 7 ultimate
       #48
    I managed to find a registry hack that will change all the fonts everywhere in Windows 7, including the logon screen, system information etc etc. Essentially it redirects Windows to the font file you specify when it's looking for MS Sans Serif, or Segoe UI for example. Thanks to Chris Pirillo of chris.pirillo.com.
    In the folowing example I used Constantia but you can choose any font you want.
    Important: in the [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts] part, make sure you have the actual filename of the font. You can find it by opening the font folder, double clicking the font you want, and then right click on the font and selecting "Properties". Bold, Italics etc all have slightly different names so make sure you get them right. I would recommend creating a restore point before doing this, just in case.
    Copy and paste the following into notebook, change the Constantia, constan.ttf, constanb.ttf etc etc to whatever you want, save as a .reg file and voila!
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes]
    "MS Shell Dlg 2"="Constantia"
    "MS Shell Dlg"="Constantia"
    "MS Sans Serif 8,10,12,14,18,24"="Constantia"
    "MS Serif 8,10,12,14,18,24"="Constantia"
    "MS Sans Serif"="Constantia"
    "System"="Constantia"
    "Microsoft Sans Serif"="Constantia"
    "Tahoma"="Constantia"
    "MS Serif"="Constantia"
    "Arial"="Constantia"
    "Segoe UI"="Constantia"
    "Times New Roman"="Constantia"
    "Times"="Constantia"
    "Small Fonts"="Constantia"
    "Tms Rmn"="Constantia"
    "Arial (TrueType)"="constan.ttf"
    "Arial Italic (TrueType)"="constani.ttf"
    "Arial Bold (TrueType)"="constanb.ttf"
    "Arial Bold Italic (TrueType)"="constanz.ttf"
    "Times New Roman (TrueType)"="constan.ttf"
    "Times New Roman Italic (TrueType)"="constani.ttf"
    "Times New Roman Bold (TrueType)"="constanb.ttf"
    "Times New Roman Bold Italic (TrueType)"="constanz.ttf"
    "Tahoma (TrueType)"="constan.ttf"
    "Tahoma Bold (TrueType)"="constanb.ttf"
    "Segoe UI (TrueType)"="constan.ttf"
    "Segoe UI Bold (TrueType)"="constanb.ttf"
    "Segoe UI Italic (TrueType)"="constani.ttf"
    "Segoe UI Bold Italic (TrueType)"="constanz.ttf"
    [HKEY_CLASSES_ROOT\Local Settings\Software\Microsoft\Windows\Shell\MuiCache]
    "@themeui.dll,-2037"="{Constantia, 8 pt}"
    "@themeui.dll,-2038"="{Constantia, 8 pt}"
    "@themeui.dll,-2039"="{Constantia, 8 pt}"
    "@themeui.dll,-2040"="{Constantia, 8 pt}"
    "@themeui.dll,-2041"="{Constantia, 8 pt}"
    "@themeui.dll,-2042"="{Constantia, 8 pt}"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontMapper\FamilyDefaults]
    "Swiss"="Constantia"
    "Roman"="Constantia"
    Cheers!
    EDIT:I should point out that this will also change the fonts in some, but not all, programs.
  10. Posts : 3
    Hello
    How to free download Arial font in Windows 7
