Pop-up Descriptions - Enable or Disable
    How to Enable or Disable Pop-up Descriptions in Windows 7 and Windows 8
    This will show you how to enable or disable pop-up descriptions that display file information when you hover the mouse pointer over files, folders, or drives, on the desktop and in Windows Explorer in Windows 7 and Windows 8.
    This does not affect pop-up descriptions for items on the taskbar like the Start Menu button and notification area icons, or the pop up when you are scrolling using the vertical scroll bar in Windows Explorer.
    EXAMPLE: Pop-up Descriptions
    OPTION ONE
    To Enable or Disable Pop-up Descriptions in Folder Options
    1. Open Folder Options in Windows 7 or Windows 8.
    2. Click/tap on the View tab. (See screenshot below)
    3. To Disable Pop-up Descriptions
    A) Unheck Show pop-up description for folder and desktop items, then click/tap on OK. (See screenshot above)
    4. To Enable Pop-up Descriptions
    A) Check the Show pop-up description for folder and desktop items, then click/tap on OK. (See screenshot below step 2)
    OPTION TWO
    To Enable or Disable Pop-up Descriptions using a REG File
    1. To Disable Pop-up Descriptions
    A) Click/tap on the Download button below to download the file below, and go to step 3 below.
    Disable_Pop-Up_Descriptions.reg
    Download
    2. To Enable Pop-up Descriptions
    Enable_Pop-Up_Descriptions.reg
    Download
    3.Save the .reg file to your desktop.
    4.Double click/tap on the .reg file to merge it.
    5. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.
    6. When done, you can delete the downloaded .reg file if you like.
    OPTION THREE
    To Enable or Disable Pop-up Descriptions in Registry Editor
    1. Press the Windows + R keys to open the Run dialog, type regedit, and press Enter.
    2. If prompted by UAC, then click/tap on Yes.
    3. In regedit, go to: (See screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
    4. In the right pane, double click/tap on ShowInfoTip to modify it. (See screenshot above)
    5. To Enable Pop-up Descriptions
    A) Type 1, click/tap on OK, and go to step 7 below. (See screenshot below)
    6. To Disable Pop-up Descriptions
    A) Type 0 (number zero), click/tap on OK, and go to step 7 below. (See screenshot above)
    7. Close regedit.
  1. Posts : 3
    windows 7
    Disable pop-ups when mouse hovers over hyperlinks/icons
    Have changed the registry, changed the file view options, all to no avail. Why does windows 7 not recognize the changes made and work properly?
  2. Posts : 72,094
    Hello Tom,
    Could you post a screenshot of this so that we can see exactly what you are seeing and at what location this is at? :)
  3. NoN
    Hi Brink, again need your skill!
    I do want to get rid of the pop ups only in the taskbar and the start menu. When i disable by uncheck "show pop-up description for folder and desktop items in the "folder option", it naturally disable it inside the explorer menu, but i do need pop-up inside explorer to browse the weight/dates of the files.
    Is there a trick in to set this correctly? Kind of dword "ShowInfoTipInExplorer" only?
    I might try that if it works...
    Thanks, Ar.
    edit:
    Well, disable it doesn't turn off onto the taskbar...but inside explorer even when checked "display info pop up size inside folder"
    and adding in the registry doesn't seems working aswell!:)
  4. Posts : 72,094
    Hello NoN,
    Sorry, but this tutorial will not work for that.
    I have not found a way to do this yet.
  5. NoN
    Brink said:
    Hello NoN,
    I saw that...
    The two exemple pictures under the "note box" that's what it wanted to have....in explorer.
    For the taskar bar, well it not so annoying as on my screen the pop up are not so big...
    It was only in the start menu on the right side, where pop up windows are oversized....
    Thanks.
  6. Posts : 14
    Hi Shawn,
    I used Option 1 but its only partly working. It works alright for files showing 3 to 4 lines of info,
    when I hover the mouse over a file. But with Folders it only shows Date Created:
    Please let me know what can I do to get the info as shown in your pic..
    I also need Folder is empty.. tip on empty folders. It shows Date Created
    even on empty folders.
    Thanks.
  7. Posts : 72,094
    Hello Andy,
    Using step 4 in OPTION ONE should allow you to have the folder details pop-up when you hover the pointer over a folder like that. It may vary from folder to folder for what you will see in it's details pop-up. Does this happen on some folders, or all folders? Even the same on in the screenshot?
  8. Posts : 14
    Hi Brink
    Thanks for replying. This is happening to all the folder irrespective of its content.
  9. Posts : 72,094
    Could you post a screenshot of this on your computer to see if anything may stand out as a reason why?
    In the mean time, you might see if running a sfc /scannow command may help.
