Windows 7: System Reserved : Create Using Disk Management
07 Jul 2011   #60
PunchsucKr
Windows 7 Ultimate x86
i have an issue, first of all it wont let me enter 200mb (100mb for that matter), i drag it and its some size like ~240mb, then when i use the counter to manually enter 200, it also tries to create unallocated space to the right of the partition in addition to the left one.
posting some screenshots using the installer version cause its behaving in the same way,in screen3, i entered manually 200 mb, and its still creating ~251mb as can be seen in the screen4.
just wanna confirm first i hope its the general behavior and its not gonna ruin my hard drive or something like that ??
System Reserved : Create Using Disk Management-capture4.png
System Reserved : Create Using Disk Management-capture1.png System Reserved : Create Using Disk Management-capture2.png System Reserved : Create Using Disk Management-capture3.png
07 Jul 2011   #61
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Naw it weird like that, just accept the closest to 200MB it gets and carry on.
07 Jul 2011   #62
PunchsucKr
Done :) but could only manage the 100 mb cause for some reason it had started givin an error "the last operation will create an overlapping partition. its a bug of partition wizard, and your last operating (?) will be cancelled." whenever i used a value in the 200 range.
07 Jul 2011   #63
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
You did good, I've seen that 'bug' a couple times; all will be well.
07 Jul 2011   #64
PunchsucKr
one more issue ... max numbr of primary partitions
07 Jul 2011   #65
PunchsucKr
i suppose formatting via partition wiz is the answer to that ? like you showed here System Reserved : Create for Dual Boot
07 Jul 2011   #66
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
How many partition does the SysResv make, post a snip of Windows 7 disk management.
07 Jul 2011   #67
PunchsucKr
Here's the snip, 3 are primary partitions, 2 logical drives.
edit: i suppose if i merge two primary partitions, then it would create it since even partition wiz is saying it cannot create a partition because of lack of mbr slots.
System Reserved : Create Using Disk Management-capture.png
07 Jul 2011   #68
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
There are allowed 4 partitions in the MBR partition structure, either 4 Primary's or 3 Primary's and an Extended, inside the Extended partition there can be as many Logical drives as there are available drive letters.
If you want to, you can right click the D: partition in Partition Wizard and convert that to a Logical drive and "accept" the changes, then the SysResv can be created as a Primary.
Be sure to keep me informed.
07 Jul 2011   #69
PunchsucKr
ok thanks for that info. so can i use the installed version to mark as logical?
Changing System Reserved information in Disk Management
Hello all. I have recently done a repair install to fix an issue with Windows Media Player. But before that, I had changed the C drive or partition to active, and have read just now that the system reserved part should be marked active. Can I switch it back to active without anything bad...
General Discussion
Disk management - system reserved
Win 7 Home Premium 64-bit SP1. What is system reserved used for and why do I need it if I already have a Recovery partition setup By Acer Aspire 7741Z? ...
Backup and Restore
I have now created this as an actual tutorial that can be viewed at this link below. --> System Reserved : Create for Dual Boot <-- This method goes with this tutorial at the link below but it was too much for the main body of the tutorial as it made the entire work, as a whole too long and...
Installation & Setup
Create the Windows 7 System Reserved Partition for use with a Dual Boot This shows how to create the new Windows 7 System Reserved partition for use in a dual boot situation when you want to install a second Operating System to the first position on the Hard Disk Dive so you can remove the older...
Tutorials
create a system reserved partition after install?
I have a bit of a problem. I recently got a new SSD and configured it to make it my boot drive. I kept my old installation on my hdd and also made a new partition on that device to hold all of the program files, data, etc. Whenever I was finished installing all the programs that I had on my old...
General Discussion
