Windows 7: System Reserved : Create Using Disk Management
07 Jul 2011   #70
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
I wouldn't, I'd use the boot disk; that's asking for trouble, IMMHO!
07 Jul 2011   #71
PunchsucKr
Windows 7 Ultimate x86
ok then :P
done :)
now the main part lol..hopefully no more issues will crop up
07 Jul 2011   #72
PunchsucKr
By the way, is it possible to use the whole 125mb instead of 100?
07 Jul 2011   #73
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Quote   Quote: Originally Posted by PunchsucKr View Post
Yeah, use it all, the more the merrier!
07 Jul 2011   #74
PunchsucKr
ok going ahead with it. will post back soon. thanks.:)
07 Jul 2011   #75
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
OK.
07 Jul 2011   #76
PunchsucKr
Done
Startup repair repaired it in 2 tries.. the third time it didn't find any errors. :)
On those two tries it was referring my system disk to be g:, i thought here we go again...lol but turns out upon booting into windows again its now c:.
Thanks for all the help Bare Foot Kid...much appreciated.:)
System Reserved : Create Using Disk Management-capture2.png
07 Jul 2011   #77
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
I'm glad I could be a help and thanks for the update! :)
07 Jul 2011   #78
PunchsucKr
One more thing, its still showing 'detected operating system on winre as windows 7 (recovered) on g: local disk', will it pose some problem while i'm manipulating the partitions in future when i add the extra hdd?
07 Jul 2011   #79
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Does the SysResv have a drive letter? if it does remove it using Windows disk management.
Changing System Reserved information in Disk Management
Hello all. I have recently done a repair install to fix an issue with Windows Media Player. But before that, I had changed the C drive or partition to active, and have read just now that the system reserved part should be marked active. Can I switch it back to active without anything bad...
General Discussion
Disk management - system reserved
Win 7 Home Premium 64-bit SP1. What is system reserved used for and why do I need it if I already have a Recovery partition setup By Acer Aspire 7741Z? ...
Backup and Restore
System Reserved : Create for Dual Boot
I have now created this as an actual tutorial that can be viewed at this link below. --> System Reserved : Create for Dual Boot <-- This method goes with this tutorial at the link below but it was too much for the main body of the tutorial as it made the entire work, as a whole too long and...
Installation & Setup
Create the Windows 7 System Reserved Partition for use with a Dual Boot This shows how to create the new Windows 7 System Reserved partition for use in a dual boot situation when you want to install a second Operating System to the first position on the Hard Disk Dive so you can remove the older...
Tutorials
create a system reserved partition after install?
I have a bit of a problem. I recently got a new SSD and configured it to make it my boot drive. I kept my old installation on my hdd and also made a new partition on that device to hold all of the program files, data, etc. Whenever I was finished installing all the programs that I had on my old...
General Discussion
