Windows 7: System Reserved : Create Using Disk Management
07 Jul 2011   #80
PunchsucKr
Windows 7 Ultimate x86
No it doesn't.
Edit: by the way i should mention here, windows dunno why has a habit of screwing around with my drive letters after a reinstall. i have just reinstalled it a couple of days ago (the first time since i got this system) and it had modified my drive letters i really don't know why so i had changed them to the original order since they were breaking a few things apart from the change perception after being used to the order for years.
07 Jul 2011   #81
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Post a maximized snip of disk management, not some little ol thing, for me to see the whole thing.
07 Jul 2011   #82
PunchsucKr
Here it is... also do note the edit on my last post.
System Reserved : Create Using Disk Management-capture.png
07 Jul 2011   #83
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Everything looks to be in order, are all the contents of the partitions/drives present?
I don't have a clue why it would break the drive letters, creating the SysResv shouldn't have any issue with that though.
07 Jul 2011   #84
PunchsucKr
Yeah all contents are present and accessible. this drive letter issue also used to happen back when i was on xp (and on a different computer)...maybe cause of many partitions or cause it might've arranged them in alphabetical order according to the labels during the install?
07 Jul 2011   #85
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Quote   Quote: Originally Posted by PunchsucKr View Post
If that's what you are referring to, it will do that all by its lonesome.
07 Jul 2011   #86
PunchsucKr
Well anyways its working fine so no worries. i'l only have 3 partitions on each drive from now on hopefully it should sort itself out.
07 Jul 2011   #87
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Have a look at this one!
Partition / Extended : Logical Drives
07 Jul 2011   #88
PunchsucKr
Did that..some good info over there..
I checked with cmd on winre, it lists
c: as system reserved
d: my present d
e: as present e
f: as my present g:
g: as windows partition
h: as my present f:
07 Jul 2011   #89
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Yeah they don't always agree, this first one is from my machine in diskpart in an elevated command window while in Windows 7
click to enlarge
System Reserved : Create Using Disk Management-2.jpg
and this one is booted to diskpart
DISKPART : At PC Startup
System Reserved : Create Using Disk Management-1.jpg
this is disk management
System Reserved : Create Using Disk Management-3.jpg
Changing System Reserved information in Disk Management
Hello all. I have recently done a repair install to fix an issue with Windows Media Player. But before that, I had changed the C drive or partition to active, and have read just now that the system reserved part should be marked active. Can I switch it back to active without anything bad...
General Discussion
Disk management - system reserved
Win 7 Home Premium 64-bit SP1. What is system reserved used for and why do I need it if I already have a Recovery partition setup By Acer Aspire 7741Z? ...
Backup and Restore
System Reserved : Create for Dual Boot
I have now created this as an actual tutorial that can be viewed at this link below. --> System Reserved : Create for Dual Boot <-- This method goes with this tutorial at the link below but it was too much for the main body of the tutorial as it made the entire work, as a whole too long and...
Installation & Setup
Create the Windows 7 System Reserved Partition for use with a Dual Boot This shows how to create the new Windows 7 System Reserved partition for use in a dual boot situation when you want to install a second Operating System to the first position on the Hard Disk Dive so you can remove the older...
Tutorials
create a system reserved partition after install?
I have a bit of a problem. I recently got a new SSD and configured it to make it my boot drive. I kept my old installation on my hdd and also made a new partition on that device to hold all of the program files, data, etc. Whenever I was finished installing all the programs that I had on my old...
General Discussion
