#20
Thanks, that should be alright...I'm gonna try here the appropriate:
Partition / Extended : Logical Drives
"Method Two", Nice...
I know that can't be a recovery partition from Toshiba, because I already had a 10 GB partition labeled "Recovery", but after I messed with the partition layout (I installed Ubuntu), it was no longer useful and when I reinstalled Windows 7, I took off that partition and formatted the partition that Windows 7 was installed and reinstalled it in that same partition.
If you want to recover all the space on the HDD and create the SysResv at the suggested 200MB, have a look at this information, it would be more useful to do it this way after you have made back-ups of any data you need to save.
After you have copied out or made back-ups of the data you need to save to external media, use Step One of this tutorial at the link below to do a wipe (secure erase) to the entire Hard Disk Drive / Solid State Drive.
Either way, running the "clean all" then creating and formatting the partition(s) using diskpart will get you the best possible space to do a clean install of Windows 7 to; you can always extend the Windows partition to include the remaining unallocated space on the HDD / SSD or create additional Primary partitions or an Extended partition after the installation completes if you choose.
- Then if you do not want to create the new Windows 7 "System Reserved" partition use the outline in Step Two #2 to create, format and mark Active a single 100GB partition to do the installation to.
- If you do want to create the "System Reserved" partition use the outline in Step Two #3 to create, format and mark Active the System Reserved partition and then create and format the 100GB partition to do the installation to.
SSD / HDD : Optimize for Windows Reinstallation
DISKPART : At PC Startup
So I would have to reinstall Windows?If you want to recover all the space on the HDD and create the SysResv at the suggested 200MB, have a look at this information, it would be more useful to do it this way after you have made back-ups of any data you need to save.
Only if you want to, it's your choice.
If you just want to create a 200MB System Reserved partition and make it the "System" partition; let's do this one step at a time.
First do you have a Windows 7 installation disk or a created repair disk that you can use?
I believe I do have a Windows 7 installation disk
Edit: Actually I don't know if I really need to create one since I have a installation disk that has the same options, right?
If you have installed the Windows 7 SP 1 the installation disk you have may not work so it would be best to use Option One in this tutorial at the link below to create one that you can use if needed.
How to Create a Windows 7 System Repair Disc
Do that and post back here and then we'll go forward.
A CD would be best, I'm just concerned that if something goes wrong and you need to do a startup repair to correct boot issues that without the correct version disk you won't be able to and you will be left with a machine that won't boot at all.
