System Reserved : Create Using Disk Management
Page 6 of 11 FirstFirst ... 45678 ... LastLast
  1. Posts : 22,814
    W 7 64-bit Ultimate
       #50
    PunchsucKr said:
    EDIT: Furthermore is it necessary to use their bootable disk or can i just use the installer?
    It would be very wise to use the boot disk, it's a lot more reliable than the installed version.
    Here you go, thanks for the heads-up about the link, I have fixed that.
    First download the Partition Wizard Bootable Disk (PWBD) ISO file to the desktop, be sure to get the PWBD and not the installed version; scroll down to see the download link for the bootable CD ISO file at this link below.
    Then use ImgBurn to burn the ISO to a CD, at no greater than 4x speed with a verify; it was designed for use and works best from a CD rather that a then boot the created CD to make the changes.
  2. Posts : 65
    Windows 7 Ultimate x86
       #51
    Ok will do! Burning it now. Hopefully everything goes according to plan. I'm taking a c drive image just in case.
  3. Posts : 22,814
    W 7 64-bit Ultimate
       #52
    Are you using the free Macrium program?
  4. Posts : 65
       #53
    No using win 7's builtin backup's system drive image.
  5. Posts : 65
       #54
    The iso downloaded is at 37.5mb while the website states 39 mb.. whats up with that??
  6. Posts : 22,814
    W 7 64-bit Ultimate
       #55
    How has that been working out for you?
  7. Posts : 65
       #56
    Presently its still just backing up... will have to restore sometime to find out lol
  8. Posts : 22,814
    W 7 64-bit Ultimate
       #57
    Some have serious issues with the default Windows 7 imaging program.
  9. Posts : 65
       #58
    Only time will tell lol.. well it burnt n all and backed up. M goin in
  10. Posts : 22,814
    W 7 64-bit Ultimate
       #59
    It's very easy, just follow the tutorial to do the shrink/resize, then after the resize completes reboot and use Windows disk management to do the create, not PW.
