Page 21 of 51 FirstFirst ... 11192021222331 ... LastLast
  1. Posts : 461
    Win 10 Pro x64, Win 7 Pro x64
       #200
    mac173 said:
    With Avast, you are not opening the program from the system tray, you are bringing up a minimized program. When you drop the Avast window, it does not close, it minimizes to the system tray, so its a single click to maximize again.
    That is also why the shortcut did not work. It cannot open up two sessions of Avast.
    Thank you, mac, I appreciate your reply!
    That seems logical enough. What confused me is that the tray icon would not load at startup, (which it did load @ startup on my XP machines, hence the ques. "is this new in 7")) only after I opened the UI w/ the shortcut & then minimzed to tray.
    Unfortunately this shortcut "trick" for lack of a better term has opened a PLETHORA of problems using Avast in Win 7 x64, starting with this one (posted @ Avast forum) ...now I find that I cannot scan a singular file or folder (using the right-click "Scan with Avast... context menu) which is also explained by your reply: "...It cannot open up two sessions of Avast"
    Looks like I have two choices:
    1) abandon this elevated program shortcut & live with the UAC prompt at startup as described in my topic @ Avast. No one there has provided ANY assistance, I stumbled on a temporary registry hack to disable the UAC prompt @ startup & they told me to mark the thread as "resolved" so they could close it out.
    WTF?????
    2) abandon Avast & find another (FREE) AV---NOT AVG, M$$E OR ESPECIALLY NORTON that won't be such a hassle running in Win 7.
    Any suggestions, anyone?
    Thanks!!
  2. Posts : 461
       #201
    Solution found: Avira AntiVir Personal - Free Antivirus
    No UAC prompts on boot, no shortcut hacks or tweaks needed, Icon loads in tray.... IOW, the way an AV should work!!
  3. Posts : 72,052
       #202
    That's great news. Thank you for posting back with your solution. :)
  4. Posts : 85
    Windows 7 Home Premium
       #203
    Another option
    I just want to add this. I was having some problems on my laptop, and was advised to stop using Avast (some conflicts since resolved). On the advise of one of the people here, I installed Windows Security Essentials.
    It works fine. I have had no problems, and when I did get an infected file it found it and blocked it with no problem. It even found a trojan that Avast had missed.
    I am always skeptical of Microsoft, but MSE is working for me.
    P.S. No UAC prompts from MSE.
  5. Posts : 824
    Windows 7 Professional 32-bit (6.1, Build 7600)
       #204
    Greg S said:
    Brink said:
    Hello Greg,
    Yes, at step 20 under the Shortcut tab in the shortcut's properties, you can select Minimized in the drop down menu to the left of Run and click OK to stop it.
    Ah, but it's not a shortcut. The task name was added to Local Machine Run in the registry. HD Tune wouldn't auto start without it
    Figured this one out by accident. Anything that needs auto starting via HKLM run or HKCU run needs some tweaking done in the scheduled task. The trigger for the task has to be set for "At log on". When this is done, the elevated task runs at startup/logon and without the cmd popup window in addition too, no startup entry needed in the registry.
    Task - Create to Run a Program at Startup and Log On
  6. Posts : 19
    windows 7 home premium 64 bit
       #205
    At last UAC notice killer
    Brink,
    I just found this tutorial ("How to Create an Elevated Program Shortcut without a UAC Prompt" by accident. I have been chasing around through various threads, forums, websites, etc. looking for this solution since getting Windows 7 a few of months ago. The problem that I had in finding a solution was that I did not refer to the need to 'elevate' the program in order to avoid the dreaded UAC notice but rather by every other description, including shield on icon, UAC notice, etc.
    Your solution is quite easy to follow. One would think that Microsoft would incorporate it into a 'single' step for users.
    Thanks very much for your assistance.
  7. Posts : 72,052
       #206
    You're most welcome Colion. :)
  8. Posts : 1,508
    Lion
       #207
    Hi Brink,
    I am trying to start 3 programs. Let me tel you the hiccups I face.
    We are in a domain environment, and all users are generic users, meaning no admin rights. For our day to day chore of works, we need 3 programs to be started. They are,
    1. Command prompt as a admin
    2. Apache tomcats monitor tomcat as a admin
    3. SQLPlus from Oracle as a admin
    Now, when the generic users tries to start the program, it shows access denied. So, they right click and select run as admin. But it asks for a password. I personally go to their place and provide the password. Due to avoid this, I have tried to create the task scheduler, but it doesnt work. When checked the history, it says the program as started, but can be seen nowhere, even in the task manager.
    I tried now on my 7 machine, both command prompt and Tomcat thingy did nothing rather than a command prompt flash for a second.
    Help me out!!!
  9. Posts : 72,052
       #208
    Hello Chan,
    Unfortunately, I have not found a way to be able to run a elevated program in standard user account without getting a prompt to enter an administrator's password.
  10. Posts : 1,508
    Lion
       #209
    Any other possible workarounds..
