Page 2 of 51 FirstFirst 123412 ... LastLast
  1. Posts : 1,326
    Windows 10 Professional 64-bit
    Hi there Brink.
    I wanted to know if it's possible to do this trick for a software that I use... from the context menu like Notepad ++. I hate the bullcrap that it can't write to my Vista partition and I want to use this workaround for it. Is there a way?
  2. Posts : 72,059
    Hello Sébastien,
    Sure. You would just create the shortcut in this tutorial, then add this to the registry:
    [HKEY_CLASSES_ROOT\*\shell\Notepad++]
    [HKEY_CLASSES_ROOT\*\shell\Notepad++\command]
    @=”\”C:\\Program Files\\Notepad++\\Notepad++.lnk\” \”%1\”"
    Substitute C:\\Program Files\\Notepad++\\Notepad++.lnk\ with the full path that you saved the shortcut at instead though, but leave the same amount of slashes in it.
  3. Posts : 12,177
       #12
    This is great for the programs used daily.
    Easy to follow and worked the first time.
  4. Posts : 72,059
    You're welcome Dave. :)
  5. Posts : 5
    This was exactly what I was looking for!
  6. brj
    Win7 Home Premium 32
       #15
    hi,
    i do have problems creating a tasks with a "normal" user because of insufficient privileges. when i create the task with an administrator, then the normal user cannot run the task, because he's not allowed to.
    jakob
  7. Posts : 72,059
       #16
    Hello Jacob, and welcome to Seven Forums.
    If you mean creating elevated shortcuts for programs, then the only way a non-administrator account can run them is to provide the administrator's password when prompted by UAC. Otherwise a Standard or Guest account will not be able to run anything that requires UAC permission to run as administrator.
  8. brj
       #17
    hi brink,
    thank you for your answer.
    I tried to create a simple task running notepad.exe with a standard user. This works as long as i do not check "Run with highest privileges". When i check this option a dialog pops up asking for a user and the password. neither the standard nor the administrator user is accepted.
    Actually i wanted to run RMClock as a standard user
    jakob
  9. Posts : 72,059
       #18
    You may only be able to run in an administrator account.
  10. Posts : 1,965
    win 7 X64 Ultimate SP1
       #19
    UAC and admin shortcut
    Excellent! Friend. I knew there was a way around that nasty UAC prompt. I also knew that I din't know enough to do it.
