Page 39 of 51 FirstFirst ... 29373839404149 ... LastLast
  1. Posts : 2
    Windows 7 Home Premium 64 bit
       #380
    Thank you for your quick response. Unfortunately, I cannot figure out how I choose the elevated shortcut. When I go to "Open with" none of the programs seem to be the one for the shortcut. I typed in what I thought was the path from looking at the "properties" of the shortcut but that didn't work. In addition, the path I typed brought up an icon that says "Manages scheduled tasks". I tried something else but that resulted in a third icon showing in "Recommended Programs". Now it seems I can't delete either one of these "Recommended Programs" that do not work. Any ideas??
  2. Posts : 72,049
       #381
    You should be able to click on "Choose default program", then "Browse" to be able to navigate to and select the shortcut like under step 3.
    Open With - Change Default Program
  3. Posts : 2
    WIN7 Home Premium x64
       #382
    Task Scheduler & App Options at startup
    Have turned to this Forum many times for solutions, though, this is my first posting.
    After reading a posting in the HowToGeek column, I utilized Task Scheduler to automate running SyncToy for doing backups. Today, however, I ran into several issues attempting to automate the Malwarebytes application.
    Your script on bypassing the UAC was spot on. However, once the app starts up, it stops at the screen offering "Quick Scan" and "Full Scan" options. I disabled the prompt for updating, but cannot determine how to just get things to run without my interaction. (which defeats the whole purpose of this script). Subbing in other .exe files within the program's folder had no effect.
    When a program opens as this one does, asking for user selections before it proceeds, is it simply not possible to automate the process as I did with the SyncToy app?
    Thanks.
  4. Posts : 161
       #383
    Thanks.
    I have Malwarebytes as well but I'm only using the Task Scheduler (UAC bypass) to launch the main MBAM console, which starts up in the "Scanner" tab, as you mentioned.
    I asked about this at the MBAM forum, whether there are shortcut keys that can be used with a script, once the main console launches.
    Unfortunately, MBAM's console is limited without the mouse. I haven't as yet seen a way to switch to the other tabs, as with the <ctrl> tab function in IE, etc.
    I thought about writing a script (using Autohotkey) with mouse x/y coordinates, to do some things with MBAM's console but I put that idea on my back burner for now.
    MBAM does have several command-line options, like resetting the scanner schedules, but there weren't any commands available that I was interested in using at the time I looked into it.
    The list of non-interactive command-mode items that can be done, from CMD or internally in a script, are are listed in the "help" index from the "about" tab, then the "help" button. The index has a section labeled "Command Line Parameters".
  5. Posts : 2
       #384
    For now, having the task scheduler launch the application will serve as a reminder to run mbam. (at least until I throw down a buy the full version, to set up ongoing processes).
    thanks for the very prompt reply.
  6. Posts : 25
    W7 x86
       #385
    I used the info in this Tutorial which worked well, but it soon dawned on me that the applications seemed to be taking a long time to run.
    Than the penny dropped - Scheduled Tasks run at priority 7 by default (which is lower than directly run applications typically run at) and the Task Scheduler does not directly provide a way to set priorities. So I Exported each task [that I had added] (as XML), deleted each task, edited the XML to change priority to 6 (which makes all the difference) and then Imported the tasks again. Problem solved.
    Might I suggest that the Tutorial could mention the priority issue and its solution.
    Whilst on the subject of priorities, they should not be set too high - 4 to 6 should be adequate for most purposes. Setting the priority too high can cause instabilities (esp. priorities 0 & 1) as system critical processes which are vital to the systems smooth operation can can held back.
  7. Posts : 925
    Windows 10 Pro
       #386
    Batch - How do you know that Scheduled tasks run at a priority 7 ?
  8. Posts : 5
    Hi Brink,
    very nice guide, thanks a lot,
    one question, will this work also on standard users non admin or power users?
    Thanks in advance.
  9. Posts : 72,049
       #388
    charli1 said:
    Hi Brink,
    Thanks in advance.
    Hello Charli,
    I'm afraid this will only work with administrator accounts. However, you could use the method in the tutorial below with all users though. :)
    Elevated Program Shortcut - Create for Standard User
  10. Posts : 5
    Brink said:
    charli1 said:
    Hi Brink,
    Thanks in advance.
    Hello Charli,
    Thanks mate.
