Page 44 of 51 FirstFirst ... 344243444546 ... LastLast
  1. Posts : 72,052
       #430
    LOL, it's always nice when it fixes itself for you.
    Did you have Winamp set to "Run as administrator" using compatibility mode by chance?
    Run as Administrator
  2. Posts : 1,364
       #431
    yes, why do you ask?
    (feed me knowledge) ...
  3. Posts : 72,052
       #432
    If so, then you could have turned it off to not get the UAC prompt.
    Plus, that could be why it stopped when you renamed the .exe since it was registered in the registry with the old name.
    (option three)
    Compatibility Mode
  4. Posts : 1,364
       #433
    (option three)
    Compatibility Mode
    'Turned it off'? You mean uncheck the 'Run as Administrator' box or uncheck the 'Run in Compatibility mode' box or uncheck both?
  5. Posts : 72,052
       #434
    The "Run as administrator" option in Option 1 or 3 below.
    Compatibility Mode
  6. Posts : 1,364
       #435
    Re-named program back to original and tried all suggestions to best of my understanding. No joy. Fortunately this is the only program on my machine that prompts w/uac. Changing the program name eliminates the annoying prompt and produces no peripheral problems. I happy - thx Shawn.
  7. Posts : 72,052
       #436
    The main thing is that you got it to work how you wanted. :)
  8. Posts : 1,364
       #437
    Yep!
    BTW, I notice in the 'information' box of post #1 that this tutorial is applicable to "any installed program". Winamp certainly qualifies. However, I notice a UAC prompt appearing upon invocation of certain Windows programs, e.g. device manager, task scheduler, sys config., etc.. Is it ok to make shortcuts for these? Being the only user on this machine and my account being an 'admin' account, I question why I am getting these prompts to begin with.
  9. Posts : 72,052
       #438
    Sure, you could use it for them as well.
  10. Posts : 1,364
       #439
    I rarely invoke these so I probably won't. However, it is good to know that it's ok.
    Thx for your time sir.
