Page 46 of 51 FirstFirst ... 364445464748 ... LastLast
  1. Posts : 2
    Windows 8.1 Professional 64Bit
       #450
    thanks for the reply!
    hmm is this a Windows 8.1 limitation?
    (because the guide on the first post mentioned it could be avoided :/)
    but thanks really! glad I didn't have to disable UAC
  2. Posts : 72,052
       #451
    Yeah, running the shortcut minimized doesn't seem to work anymore to stop the command prompt flash. :)
  3. Posts : 1
    Microsoft Windows 8 (6.2) 64-bit (Build 9200)
       #452
    Oh My God, thank you thank you sooooo much, have been having so much difficulty with this, was trying to create a schedule where a system restore point is create upon logging on / at start up, without prompting the UAC, this has helped so much.
  4. Posts : 7
    windows 7
       #453
    I'm having trouble getting a programme called blue iris to start automatically at start-up but when I carry out post instructions and restart, command prompt flashes up and disappears but ten nothing. I am using windows 7 home premium and it says administrator account in control panel - could it be that I don't have a password set on the account?
  5. Posts : 72,052
       #454
    Hello Rincal,
    Yes, the administrator account will need to be password protected.
    Double check in Control Panel -> User Accounts to see if it password protected. :)
    Password - Create for a User Account
  6. Posts : 7
    windows 7
       #455
    Brink said:
    Hello Rincal,
    Created a password for account but still same thing, command prompt quickly flashes on and off then nothing.
    I can start program from original shortcut without problem but when I try to start from created short cut the same thing as above.
    I've gone through it many time - Any ideas?
  7. Posts : 1,049
    Windows 7 Pro 32
       #456
    Try this: In scheduled task, change the start of the value for Add arguments (optional) from /c to /k
    Then the command prompt won't flash but stay visible. If something is wrong with that argument hopefully you'll now be able to see the error message.
  8. Posts : 7
    windows 7
       #457
    I managed to sort it.
    I noticed that when I had the task selected in scheduler a clicked the run button in bottom right window, the command prompt flashed and this time the programme started - I knew that the task was ok so had to be problem with the shortcut. I believe that my error was not putting quotes in the first part of shortcut creation. any way all working ok.
    thanks Brink for creating post/help and thanks Tookeri.
  9. Posts : 72,052
       #458
    Great news Rincal. :)
  10. Posts : 1
       #459
    WOW, Mr. Brink you are a genius, thanks a lot, works perfectly on windows 8.1 Pro.
