#500
I wrote a reply a few minutes ago that appears to have disappeared. I guess I'll try retyping it.
I found this tutorial incredibly helpful but can't seem to get it to work for one of my tasks. I got it to work with CCleaner, but the task I'm struggling with is running two .exes simultaneously. I checked and double-checked and everything looks good, but when I hit run or when I use the desktop shortcut, it doesn't run either program.
The two actions link to these locations:
/c/start "ESO AddOn Clients" "C:\Documents\Elder Scrolls Online\live\AddOns\TamrielTradeCentre\Client\Client.exe"
/c/start "ESO AddOn Clients" "C:\Users\Veronica\AppData\Local\Minion\Minion.exe"
The apps are standalone exes for the game The Elder Scrolls Online. Currently, I have to select each exe individually and hit yes on the UAC prompt for each one. It's really annoying, so I was really hoping there was a way to just have one button run both, without the prompt. I edited the shortcut to bypass the UAC and to run in administrator mode. I'm not really sure how I messed up or if it just can't work with two exes simultaneously. If that's the case, what are my options?
Thanks in advance!
