Page 11 of 51 FirstFirst ... 91011121321 ... LastLast
  1. Posts : 72,036
       #100
    Hello Kimsland, and welcome to Seven Forums.
    Yes, DMEX and I work together alot on some things. He has been noted for pointing this out. :)
    That's pretty scary that it would be that easy for malware to bypass UAC with a script like that though.
    I hope that you will be able to get Windows 7 soon as well.
  2. Posts : 6
    XP
       #101
    Thanks for the reply
    Yes I do too. But with Chris Green displaying his Roadmap draft, I might just wait for Windows 8
    But that discussion would be off topic
  3. Posts : 72,036
       #102
    True, but I suspect Windows 8 may be a few years off for it.
  4. Posts : 4
    Wow! how in the h-ll did you figure that procedure out!
    You'd think that Microsoft would just provide a switch in the programs' properties or in program compatibility panel to just bypass UAC.
    In any case, i don't think that would work in my case since when the program installs, it sets itself up to automatically run after account login. I would have to substitute the executable for the shortcut in the registry somewhere i think.
    I guess i could delete the entry in the registry and then place the shortcut into the account startup folder.
    Now that i think about it, wouldn't it easier just to elevate the programs' priority in the registry?
  5. Posts : 72,036
       #104
    Hello Nelson, and welcome to Seven Forums.
    You might be able to elevate the program in the registry, but it will still not run at startup without getting a UAC approval pop-up unless it's a task like in this tutorial instead.
  6. Posts : 4
    Windows 7 Home Premium
       #105
    @Brink
    Is there a way to get the shortcut I made to allow me to double-click a music file and have it open Winamp that way without asking for the UAC? The shortcut opens Winamp fine if I double-click on the new shortcut, but if I try to associate the mp3 files with it, it opens the command prompt box for a second, and then nothing opens.
  7. Posts : 72,036
       #106
    Hello BrainFreeze,
    Not that I'm aware of.
  8. Posts : 4
       #107
    Brink said:
    Hello BrainFreeze,
    Figures my luck would be that way. Thanks for getting back to me.
  9. Posts : 759
    Windows 7 Enterprise x64
       #108
    BrainFreeze said:
    @Brink
    That's odd. Do you have WinAmp set as your default media player?
    Also, if you want to right click a music file, and have WinAmp open it, you can add a shortcut to the right click context menu for that function.
  10. Posts : 4
       #109
    Yep. I have Winamp set as my default for all of my audio files. Do you know of a way to get it to let me double-click on the mp3 where it opens it using that UAC shortcut?
