Page 12 of 51 FirstFirst ... 2101112131422 ... LastLast
  1. Posts : 759
    Windows 7 Enterprise x64
       #110
    BrainFreeze said:
    Yep. I have Winamp set as my default for all of my audio files. Do you know of a way to get it to let me double-click on the mp3 where it opens it using that UAC shortcut?
    Not right off hand. I've always used WMP as my default player. I'm sure there's a way to do it though. You'll just have to navigate around and find the proper setting. If you already have WinAmp set as your default player, I'm surprised you get a UAC prompt. Have you already gone into the WinAmp settings? Make sure your MP3 file settings have WinAmp as the default program to open them.
  2. Posts : 4
    Windows 7 Home Premium
       #111
    LOL I've checked that info numerous times, but it's set as default.
  3. Hau
    Thanks.. it works.
    but i have a question.
    i have a program with a UAC prompt too, but a little bit different.
    the UAC propmt come out with yellow colour. and at the shortcut, there was a shield like the shield at parental control's shield.
    i tried using this way, but cant works.
    an error message come out.
    "Could not start War3.exe! Make sure the loader is in your Warcraft install directory"
    Can u help me??
  4. Posts : 72,062
       #113
    Hello Hau,
    Does the game run normally? If yes, then double check to make sure that you are using the same correct EXE file or shortcut that you normally use to run the game with.
  5. Hau
    yes... i can play it with the EXE file. but there is an UAC prompt with a little bit different, like i said before.
    when i use the shortcut, i cannt be run.
    any help?
  6. Posts : 72,062
       #115
    Hau,
    You may not be able to with that program/game.
  7. Hau
    so there is no way for game?
  8. Posts : 72,062
       #117
    For that specific game it seems not to be.
  9. Posts : 759
       #118
    Hey guys, I run MSI Afterburner to control my GFX card fan speed. It needs to run right at startup, but I can't get it to elevate so I don't get the UAC prompt every time I fire up my rig. Has anyone successfully elevated MSI Afterburner? If so, how did you do it...specifically?
    A shortcut isn't much help because I need it to elevate automatically, right at startup. It's a real pain in the ass having to click on the UAC every single time I fire up my rig.
  10. Posts : 72,062
       #119
    Hello Max,
    You might see if you may be able to do this with MSI Afterburner instead to have it run at startup without the UAC prompt.
    Task - Create to Run a Program at Startup and Log On
