Page 19 of 51 FirstFirst ... 9171819202129 ... LastLast
  1. Posts : 10,200
       #180
    Shawn,
    With settings as shown in attachment, I:
    1. started CCleaner
    2. disconnected the AC
    Result: CCleaner terminated very abruptly.
    Elevated Program Shortcut without UAC Prompt - Create-terminal-situation.png
  2. Posts : 72,127
       #181
    Now that is strange that it would gray that option out, yet still have it work. Tutorial updated to have both unchecked.
  3. Posts : 10,200
       #182
    I agree that it is strange, and I wouldn't have checked except that I've had that greying out bite me before.
  4. Posts : 3
    Windows 7 Professional x64
       #183
    After reading this thread I ran across a program called "UAC Controller Tool" by ITknowledge2 which lets you create a UAC whitelist. I thought someone here might be interested. But just so you know, I haven't tested or even installed the program yet. I wanted to post here first to get some feedback, not only if anyone has used this program but if using it will create a hole in security.
    Edit: Turns out the website that originally said this program created a whitelist was wrong... it doesn't. It only provides an easier way to change the UAC settings. Sorry for the confusion.
    Last edited by 65Cobra427SC; 10 Oct 2010 at 11:31. Reason: Change Made Based on Next 2 Posts
  5. Posts : 17,322
    Win 10 Pro x64
       #184
    I just installed it.
    I don't see where you can create a whitelist, you can change the settings right from
    the notification area without a restart, and it works for that. I don't know about the security aspect though.
  6. Posts : 3
       #185
    I just installed it and you're right. I went back to look where I got the idea of a whitelist and found the original post where it was mentioned, that poster said it created a whitelist... but you're correct, it doesn't. So basically it makes it easierto change the UAC setting but nothing more. Sorry for misleading everyone.
  7. Posts : 17,322
    Win 10 Pro x64
       #186
    That's alright, it has it's uses. you don't need to restart every time you change settings.
    You can post it with a link to it here
    FREE Great Programs for Windows 7
    some other people might be interested in it.
  8. Posts : 385
    Windows 7 Home Premium x64 OEM --> RTM clean install
       #187
    Greetings all, I have a question, please...
    I did this for a program I have that loads at startup. It's called "Green Button" by Verbatim - it's an energy saver spin-down utility for portable USB drive. I deleted the link from the start up folder, and replaced it with a new one created from the first part of the tutorial (thanks Brink), and for good measure I did the second part of the tutorial (.bat) - thanks OEM.
    Problem - it still prompts for uac. I don't know whether this has anything to do with it, but even though the program loads at boot, it cannot be seen in the sys tray - only on connection of the portable USB drive.
    Any ideas?
    Regards D
  9. Posts : 72,127
       #188
    Hello Allen,
    When you did the BAT option in the post below the tutorial, did you use the path to the shortcut created in the tutorial when creating the BAT file and only placed the BAT file in the Startup folder?
  10. Posts : 385
       #189
    Solved it - I uninstalled / reinstalled it. I don't know why, but 2 or 3 uac windows would pop up on connect, so now everything A-OK!
