Internet Explorer Compatibility View - Turn On or Off
Page 1 of 3 123 LastLast
    How to Turn Internet Explorer Compatibility View On or Off for a Website
    Websites that were designed for earlier versions of Internet Explorer might not display correctly in IE8, IE9, IE10, or IE11. When you turn on Compatibility View, the webpage you're viewing, as well as any other webpages within the website's domain, will be displayed as if you were using an earlier version of Internet Explorer.
    This tutorial will show you how to add (turn on) and remove (turn off) websites to be displayed in Compatibility View.
    Not all website display problems are caused by browser incompatibility. Interrupted Internet connections, heavy traffic, or website bugs can also affect how a webpage is displayed.
    OPTION ONE
    Through the Internet Explorer Address Bar
    NOTE: If Internet Explorer recognizes a webpage that is not compatible, you will see the Compatibility View icon button on the Address bar.
    1. To Turn On Compatibily View for a Website in Internet Explorer
    A) Click/tap on the unhighlighted Compatibility View icon button. (See screenshot below)
    NOTE: The webpage will now reload with Compatibility View turned on for it, and the website will be added to the list in compatibility view settings (Option Three below).
    2. To Turn Off Compatibily View for a Website in Internet Explorer
    A) Click/tap on the highlighted (blue) Compatibility View icon button. (See screenshot below)
    NOTE: The webpage will now reload with Compatibility View turned off for it, and the website will be removed from the list in compatibility view settings (Option Three below).
    OPTION TWO
    Through the Tools Menu
    NOTE: This will let you turn on or off Compatibility View for the current webpage.
    1. Click/tap on the Tools Menu Bar (ALT+T) item. (See screenshot below)
    NOTE: If Compatibiliy View is grayed out, then the webpage has no compatibility issues and does not need to have Compatibility View turned on for it. You can still use METHOD THREE below to turn on Compatibility View for it though if you like.
    A) Go to step 3.
    OR
    2. Click/tap on the Tools Command Bar button. (See screenshot below)
    3. To Turn On Compatibily View for a Website in Internet Explorer
    A) Click/tap on Compatibiliy View to check it. (See screenshots above)
    4. To Turn Off Compatibily View for a Website in Internet Explorer
    A) Click/tap on Compatibiliy View to uncheck it. (See screenshots above)
    OPTION THREE
    Through Compatibily View Settings
    NOTE: This will let you turn on or off Compatibility View for a webpage by adding or removing the webpage address from the Compatibility View list.
    1. Click/tap on the Tools Menu Bar (ALT+T) item, and go to step 3 below. (See screenshot below)
    OR
    3. Click/tap on Compatibility View Settings. (See screenshots above)
    4. To Add a Website to the Compatibility View List in Internet Explorer
    A) Type in the webpage address that you want to turn on Compatibility View for, and click/tap on the Add button. (See screenshot below)
    NOTE: The current webpage address will automatically be filled in for you. Just clear it if you want to add a different address instead.
    B) Go to step 6.
    5. To Remove a Website from the Compatibility View List in Internet Explorer
    A) Select a listed webpage address that you want to turn off Compatibility View for, and click/tap on the Remove button. (See screenshot below)
    6. Click/tap on the Close button. (See screenshots above)
  1. Joe
    Windows 7 RC
    Thanks for another excellent tutorial Shawn. I ran into compatibility issues with a website I visit. At first I didn't know what it was doing, then walla, your tutorial shed light on the issue. Thanks again!
  2. Posts : 72,046
    You're welcome Joe.
  3. Posts : 576
    Vista X32. Windows 7 32bit
    That was well worth the read Shawn, thanks again for the Tutorial
    Norm
  4. Posts : 72,046
    You're welcome Norm. Thank you.
  5. Posts : 3,141
    Thanks Shawn. Great job.
    Gary
  6. Posts : 72,046
    You're welcome Gary.
  7. Posts : 6
    Hi Brink, thank for the tutor.
    I wonder if I can turn on Compatibility View for all sites by default? I'm using Windows 7 x64 SP1 and I got IE 9 installed.
    Thanks!
  8. Posts : 72,046
    Hello Longnh,
    It's not recommended to use compatibility view on a website unless you are having some sort of issue with it in normal mode. However, the tutorial below will show you how to turn on compatibility view for all websites.
    Internet Explorer Compatilbility View - All Websites
  9. Posts : 1
    thanx a lot...... worth a lot.............
