Internet Explorer Compatibility View Updates
    How to Receive Internet Explorer Compatibility View Updates
    This will show you how to receive or not receive Internet Explorer Compatibility View updates through Windows Updates (typically, every 2 months) for a list of web sites that should be displayed in Compatibility View. These list updates are automatically added or removed from the Compatibilty View Settings list of web sites.
    Sites on this list are based on feedback from other IE customers: specifically, for what high-volume sites did other users click the Compatibility View button on. The data Microsoft collects from IE users is the top level domain of the website and whether the user chose Compatibility View while visiting that site (please see the IE Privacy Policy for more information). For more details, see: IEBlog : Compatibility View Improvements to come in IE
    OPTION ONE
    In Internet Explorer "Compatibility View Settings"
    NOTE: This will allow you to turn on or off receiving Compatibility View Updates at any time you like.
    1. Open Internet Explorer.
    2. Click/tap on the Tools Menu Bar item. (See screenshot below)
    A) Go to step 4.
    OR
    3. Click/tap on the Tools Command Bar button. (See screenshot below)
    4. Click/tap on Compatibility View Settings. (See screenshots above)
    5. To Turn On and Receive Compatibility View Updates
    A) Check the Include updated website lists from Microsoft (IE8/IE9) or Downloaded updated compatibility lists from Microsoft (IE10) box. (See screenshot below step 7)
    B) Go to step 7.
    6. To Turn Off and not Receive Compatibility View Updates
    A) Uncheck the Include updated website lists from Microsoft or Downloaded updated compatibility lists from Microsoft (IE10) box. (See screenshot below step 7)
    7. Click/tap on the Close button. (See screenshots below)
    Internet Explorer Compatibility View Updates-update_list.jpgInternet Explorer Compatibility View Updates-ie10.jpg
    8. Close Internet Explorer when done.
    OPTION TWO
    Using a REG File Download
    1. To Turn Off and not Receive Compatibility View Updates
    A) Click/tap on the Download button below to download the file below, and go to step 3 below.
    Turn_Off_IE_ Compatibility_View_Updates.reg
    2. To Turn On and Receive Compatibility View Updates
    Turn_On_Compatibility_View_Updates.reg
    3. Save the REG file to your desktop.
    4. Double click/tap on the REG file to merge it.
    5. Click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK when prompted to approve the merge.
    6. When done, you can delete the downloaded .reg file if you like.
  1. Posts : 1
    Windows 7 Home Premium, 64 bit operating system
    Compatibility View
    Hi Brick, Thank You so much for the easy to understand instructions for turning off Compatibility View. I was so happy with your method. Beverly
  2. Posts : 72,051
    You're most welcome Beverly, and welcome to Seven Forums. :)
  3. Posts : 3
    Windows 7 Pro x64
    Great tutorial. I d/l the disable reg file but still had the same problem. did a search of the reg with "BrowserEmulation" and found 3 more locations. I set the flags to 0 and my problem went away. I'm not sure which one actually fixed the problem as I edited them all at the same time.
    Hope someone may find this info to be useful.
    1. this one is from you.
    [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\BrowserEmulation]
    "AllSitesCompatibilityMode"=dword:00000000
    2.
    [HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\BrowserEmulation]
    3.
    [HKEY_USERS\S-1-5-21-4105843126-57720304-1097551233-1001\Software\Microsoft\Internet Explorer\BrowserEmulation]
    4.
    [HKEY_USERS\S-1-5-21-4105843126-57720304-1097551233-1001\Software\Policies\Microsoft\Internet Explorer\BrowserEmulation]
  4. Posts : 72,051
    Hello Henry, and welcome to Seven Forums.
    The AllSitesCompatibilityMode DWORD is the registry entry that is added and set by Group Policy for all users instead of the tutorial only setting the MSCompatibilityMode DWORD from the "Compatibility View Settings" GUI. I have added the AllSitesCompatibilityMode entries to the REG file download that will also turn off the Group Policy setting as well to help others that run into the same issue you did. :)
    Group Policy locations for "Turn on Internet Explorer 7 Standards Mode""
    Computer Configuration\Administrative Templates\Windows Components\Internet Explorer\Compatibility View
    and
    User Configuration\Administrative Templates\Windows Components\Internet Explorer\Compatibility View
    #2 is most likely the one that fixed this for you. The entries you have with the longer S-1-5...... number is user account and computer specific, and cannot be used by anyone else.
    Thank you,
