Lastwake Command
Page 3 of 3 FirstFirst 123
  1. Posts : 72,058
       #20
    If it turns out to be the culprit, then double check using OPTION ONE below for your network adapter properties to make sure that any "wake on" or "wake computer" type setting in the Advanced and Power Management tabs has been disabled.
    Devices - Allow or Prevent to Wake Up Computer
  2. Posts : 10
    Nova Scotia
       #21
    It says that only my mouse and keyboard can wake the computer. Ethernet isnt a device is it? just a cable?
    And the reason it says they can wake my computer now is cause i unplugged them and put them in again. But yah ive continued testing and it looks like my ethernet cable is the reason
  3. Posts : 72,058
       #22
    Ethernet would be your network adapter, which would technically be a device.
  4. Posts : 10
    Nova Scotia
       #23
    Alright thanks, it didnt have the check beside it that it could wake my computer up from sleep but i unchecked the other box. Ill let you know if the problem persists?
  5. Posts : 10
    Nova Scotia
       #24
    so yah it definitely is the ethernet, it happens when its plugged in so recently ive been taking out the ethernet, but in the settings it doesnt say that the ethernet can wake my computer. is there anything i can do against this?
  6. Posts : 72,058
       #25
    Double check your Power Options to make sure that "Allow wake timers" is disabled to see if that may be it.
    Power Plan Settings - Change
