Notification Area Icons - Customize
  1. Arc
    Thanks mate
  2. Posts : 3
    Windows 7 ultimite x64
    The batter dll
    The battery meter in system32 is batmeter.dll i dont know much about changing the icon or modding the dll files
  3. Arc
       #12
    Nice add mate Ok I am going to check there :)
    Thanks a lot And most welcome to SF
    Edit : Just checked .... it contains only bitmaps ... and no icons . It is though possible to modify those bitmaps, but it is a bit difficult to make a custom alpha channel image like this .
    I am to try .
  4. Posts : 3
    hmmm, i got the sound icon changed via another method. but i cant seem to get the pnidui.dll one to change my network icon. will that effect the wireless icon as well?
  5. Posts : 3
       #14
    Thanks for the welcome to SF :)
  6. Arc
       #15
    Will you share your method with us ? Anyway , modifying pnidui.dll changed the icon for both of my machines . I plotted the icons for 100% default display . For any other settings, the icon groups will be different .
    About wireless icon .... if you change the icons that results the wireless icon , it will be changed . As I dont use wireless , I dont know which ones are those . If you can contribute those , it would be great .
  7. Posts : 115
    7 Ultimate x64 sp1
       #16
    Modified & default sound icons
    sndvol-icons.rar
    Colored & modified network + A.center
    ActionCenter_pnidui.rar
    Attached Thumbnails Attached Thumbnails Notification Area Icons - Customize-sndvol.png   Notification Area Icons - Customize-net-act.png
  8. Arc
       #17
    sndvol-icons.rar
    Looks great , and expecting other icons too
  9. Posts : 22
    Windows 7 Professional x64
       #18
    I was just looking over this tutorial after a bit of searching and was wondering if it would be possible to change the Utorrent system tray icon. I found the correct icon to change, however, I was getting errors saying the .exe had been compressed and ResHack was having trouble reading some of it. Because of this, when I replaced and saved, it was no longer a valid 32-bit .exe file.
    Any suggestions?
  10. Posts : 115
    7 Ultimate x64 sp1
       #19
    For utorrent make 2 new icons
    main.ico 32x32 only!
    tray.ico 16x16 only!
    and put them in users ................utorrent folder.
    Attached Thumbnails Attached Thumbnails Notification Area Icons - Customize-utorrent.png
