Some times not so private...
If you've left the option for a new tab to its default "open new tab page" and don't close the window, it shows a history of tabs (sites) visited.
https://www.sevenforums.com/network-i...-browsing.html
Is there a way to create a shortcut without In Private browsing for IE8 64 bit? I'm have this problem: Odd attachment display in SF and IE 64 is the only way I can bypass it.
Hello Gary,
If you just wanted to create a shortcut to open 64-bit IE8, then you could use the path below to create it with.
%ProgramFiles%\Internet Explorer\iexplore.exeIf you meant a internet website shortcut that would open in 64-bit IE8, then step 4B in OPTION THREE of the tutorial below can help show you more on how.
Hope this helps. :)
awesome thanks - had it running in under a minute ; )
