Pin to Taskbar and Pin to Start Menu Missing from Context Menu Fix
Page 2 of 2 FirstFirst 12
  1. Posts : 72,059
    Monster,
    As a test, create a new administrator account for yourself to see if it works properly while logged in the new account. If it does, then you could just copy what you like from the old account, and delete the old account when finished.
  2. Posts : 4
    Windows 7 Ultimate x32
    Brink,
    it works
    the problem was that I was manually deleted IsShortcut from HKEY_CLASSES_ROOT/lnkfile
    I have a .reg file that repair all shortcuts..
    i hate the arrow on shortcuts and in XP there is no problem to del it, but in windows 7.... who knows
    hope to help to somebody with the atteched file ;]
    nice work
    Thanks a lot, and happy new year for everyone!
    Greetings from BULGARIA!
  3. Posts : 72,059
       #12
    That's great news Monster.
    Yeah, deleting the IsShortcut registry entry was the way to remove the shortcut arrow in XP, but it's not to be used in Vista and Windows 7 for reasons you have found out why for.
    If you like you could use the tutorial below for how to remove the shortcut arrow in Windows 7.
    Shortcut Arrow - Change, Remove, or Restore
  4. Posts : 1
    Windows 7 Home prieum 64 Bit
    Work Around Or Quick Fix Pin To Start Menu
    Hold down the Shift key while right clicking & pin to or unpin will appear as the option that was missing. I found it somewhere. Don't remember where, but I did remember what key it was. the example i'm using is I pinned to start menu an .Rtf document & it worked. Hope this helps lots of people
  5. adj
    7 ultimate
       #14
    Cannot make this tweak work - pin still not in tight-click menu
    Hi, Brink.
    Whether through idiocy (mine) or malice aforethought (M-s**t's), I cannot make this work.
    Have
    a) enabled pinning to taskbar (at least I downloaded rigth-clicked "merge" for enable_taskbar_pinned_programs, with response "successfully added to registry")
    b) downloaded and right-clicked to merge the lnk widget
    But the right-click on e.g. Downloads or Thunderbird still gives me just the following:
    Open
    Open folder location
    Include in library - Docs/Music/Pics/Video
    Restore previous version
    Send to - Compressed / Desktop/ Docs / Fax recipient / Mail recip./ DVD drive E: / BD drive F:
    /Removable Disk H:
    Cut
    Copy
    Create shortcut
    Delete
    Rename
    Properties
    For what it's worth, this is a new installation of W7 Ultimate (old one stopped working so no repair-install possible) on the C disk of the following set-up:
    Mainboard : Asus M4N78-AM
    > Chipset : nVidia GeForce 8200
    > Processor : AMD Phenom II X4 810 @ 2600 MHz
    > Physical Memory : 4096 MB (2 x 2048 DDR2-SDRAM )
    > Video Card : NVIDIA GeForce 8200
    > Hard Disk : ST3320418AS (320 GB)
    > DVD-Rom Drive : HL-DT-ST DVD-RAM GH22NP20 ATA Device
    > DVD-Rom Drive : HL-DT-ST BD-RE BH08LS20 ATA Device
    > Monitor Type : Idek Iiyama PL2409HD - 23 inches
    > Network Card : MCP77 Ethernet
    > Network Card : RT2561/RT61 rev B 802.11g
    Grateful if you can suggest what I am doing wrong (and thanks, as so often, for your indefatigablenessitude in trying to make everyone's life a little happier). adj
  6. Posts : 72,059
       #15
    Hello adj,
    Are these folders or applications that you are trying to pin?
    Folders will not have "Pin to taskbar" in their context menu. Only applications (ex: .exe file) will.
  7. adj
    7 ultimate
       #16
    Brink said:
    Hello adj,
    Thanks for swift response: they are typically applications for the taskbar, e.g. Thunderbird - but it would be useful to have Downloads in the Start Menu (think I have had it automatically before, when W7 installed, but seems to have dropped out this time)
  8. Posts : 72,059
       #17
    While folders cannot be pinned to the taskbar, you could add them as toolbars, or create shortcuts of them in Quick Launch.
    Taskbar - Pin or Unpin a Folder
    Do you have both pin context items for files on an internal hard drive?
    Since this is a removable drive, you may be able to create a shortcut for the file at a location on your internal drive, then pin the shortcut to your taskbar or Start menu.
  9. adj
    7 ultimate
       #18
    problem largely solved though mysteries remain
    A. Thank you for all your help
    B. Sorry for delay but work intervened.
    C. After 3 re-boots, the "pin to taskbar / start menu" options appeared in right-click menu, so that's done, even if W7 took its time getting there.
    D. In meantime tried your "Taskbar - Pin or Unpin a folder" tutorial, with very mixed results, and will log them there.
    E Don't understand your query re having things on internal hard drive, since all this version of W7 is on disk 0, the C drive of this pc, but probably not important now.
    F. Many, many thanks again and best wishes, A
  10. Posts : 72,059
       #19
    ADJ,
    I'm happy to hear this part is sorted. I'll see at the other tutorial for pinning folders as toolbars. :)
