If using the method in the tutorial, then yes you will still need to.
Sorry Shawn, no I meant using CCleaner. It has never worked for me yet Dinesh says it does for him, i'm wondering if you still have to kill explorer, i wouldn't have thought so but just checking.
Hy,
I used Windows 10 Transformation Pack on my Windows 7 and it changed some icons white... which is nice when I see them against my dark taskbar, but is completely invisible in that rectangle of hidden icons of the notification area.
I would like to make that area dark like my taskbar, to see...
How to Hide or Show System Icons and Notifications in Windows 7 and Windows 8
The notification area is a part of the taskbar that provides a temporary source for notifications and status. It can also be used to display icons for system and program features that are not on the desktop. The...
Hello,
My problem is some of my apps that starts with the system have an icon in the notification area (which i set to SHOW ALL) and suddenly few of them do not appear anymore, even after restart or caches cleaning.
I found that using CCleaner and checking "clean notification area cache"...
I have customized the Notification Area so that some items are hidden and some are not. However, when a program that I've set to "Show icon and notification" stops running for any reason, its customization reverts back to "Only show notifications", even after the program has been restarted. So I...
So recently I had a devastating power loss event caused by a cat, and when I restarted, to my horror, it wasnt even recognizing my brand new Crucial C300 SSD. Long story short, luckily it isnt bricked, but I had to pull my CMOS battery before it recognized again.
So now everything seems to be...
