Enhanced Mitigation Experience Toolkit (EMET)
Page 3 of 9 FirstFirst 12345 ... LastLast
  1. Posts : 72,052
       #20
    I'd have to agree with you on that as well. It sure seems like EMET is blocking or doing something to not allow them to run.
  2. Posts : 6,349
       #21
    Brink
    Did anyone figure out how to know it is working?
    That is "turned on".
    I read your directions 3 times and the pdf 3 times.
    I set per your instructions and all software so far functions.
    I set "Configure System" to max and rebooted.
    This is what I'm showing- bottom Snip. Running EMET column is empty- totally.
    "System" has a question mark as it always has since install in December.
    I thought I would take a look at EMET since the SP1 update and I'd see if this was working or not. Still haven't a clue.
    Mike
    Also
    Copied this from your post #1. Where is this window?
    Typed Performance Options in Search and found nothing.
    Attached Thumbnails Attached Thumbnails Enhanced Mitigation Experience Toolkit  (EMET)-emet.png
  3. Posts : 72,052
       #22
    Hello Mike,
    From your screenshots, EMET is working properly. EMET will gray out the DEP settings in the top screenshot since EMET is being used. You can go through the EMET User Guide from the link in the tutorial for detailed information on how it's suppose to work though.
    Hope this helps some,
  4. Posts : 17,322
    Win 10 Pro x64
       #23
    Hopalong X said:
    Brink
    Mike
    Also
    Hi Mike,
    That's in advanced system settings, performance box, settings.
    Attached Thumbnails Attached Thumbnails Enhanced Mitigation Experience Toolkit  (EMET)-capture.jpg
  5. Posts : 6,349
       #24
    Thanks Derekimo and Brink.
    Found the window.
    DEP tab selections are grayed out as you said it would be so I guess everything is working properly.
    It just would be nice to have something showing so you know the EMET was definitely active and working properly. LOL
    Mike
  6. Posts : 17,322
    Win 10 Pro x64
       #25
    DEP is grayed out as you said it would be so I guess everything is working properly.
    Mike
    You're welcome Mike.
  7. Posts : 72,052
       #26
    Found the window.
    Mike
    Just as long as those checkmarks stay green, you're ok. :)
  8. Posts : 64
    Windows 8 Pro
       #27
    Hey Brink, I just recently encrypted my virtual page file. Before I encrypted it, I installed the EMET program first. At this time, when I opened task manager and had IE running, the description would include something like "EMET- Internet Explorer- Bing." However, after encrypting, it is now just "Internet Explorer- Bing" Did the encryption do anything to EMET or affect it? Or maybe I am just seeing thiings...?
  9. Posts : 72,052
       #28
    Hello Windows 911,
    Nar, I don't think it would have. It sounds like that would just be the title of the tab that you may have had open (active tab) in Internet Explorer displaying in Task Manager at that time vs now instead.
  10. Posts : 18,404
    2.1 is out. Might want to update the download links.
    new-version-emet
    Enhanced Mitigation Experience Toolkit v2.1
