How to Create a "Credential Manager" Shortcut in Vista, Windows 7, and Windows 8
Credential Manager allows you to store credentials, such as user names and passwords that you use to log on to websites or other computers on a network. By storing your credentials, Windows can automatically log you on to websites or other computers. Credentials are saved in special folders on your computer called vaults. Windows and programs (such as web browsers) can securely give the credentials in the vaults to other computers and websites.
This tutorial will show you how to download or create a Credential Manager shortcut that you can pin and use where you like in Vista, Windows 7, and Windows 8.
EXAMPLE: Credential Manager
OPTION ONE
To Download the "Credential Manager" Shortcut
1. Click/tap on the download button below to download the file below
Credential_Manager.zip
2. Save the .zip file to your desktop.
3. Open the .zip file, and extract (drag and drop) the Credential Manager shortcut to your desktop
4. Unblock the
Credential Manager shortcut.
5. In
Vista and
Windows 7, you can now
Pin to Taskbar (Windows 7 only) or
Pin to Start Menu, add to
Quick Launch,
assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
6. In
Windows 8, you can
Pin to Taskbar on desktop,
Pin to Start screen, add to
Quick Launch,
7. When finished, you can delete the downloaded .zip file if you like.
OPTION TWO
To Manually Create the "Credential Manager" Shortcut
1. Right click or press and hold on an empty area on your desktop, and click/tap on
New and
Shortcut.
2. Copy and paste the location below into the location area, and click/tap on the
Next button. (see screenshot below)
%windir%\explorer.exe shell:::{1206F5F1-0569-412C-8FEC-3204630DFB70}
3. Type
Credential Manager for the name, and click/tap on the
Finish button. (see screenshot below)
NOTE: You can name this anything you would like though. 4. Right click or swipe down on the new
Credential Manager shortcut, and click/tap on
Properties.
5. Click/tap on the
Shortcut tab, and click/tap on the
Change Icon button. (see screenshot below)
6. In the line under "Look for icons in this file", copy and paste the location below, and press
Enter. (see screenshot below)
%SystemRoot%\system32\Vault.dll
7. Select the icon highlighted in blue above, and click/tap on
OK. (see screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click/tap on
OK. (see screenshot below)
9. In
Vista and
Quick Launch,
10. In
Windows 8, you can
Quick Launch,
