How to Remove a Listed Program in Default Programs for Windows 7 and Vista
By default, you would normally
uninstall a program to remove it from the list of programs in
Set Default Programs. This will show you how to remove your choice of any program listed in the Windows 7 and Vista
Set Default Programs window without having to uninstall the program instead.
You must be logged in as an
administrator to be able to do this tutorial.
This can be handy if you uninstalled a program and it was not removed from the list in Set Default Programs, or you just did not want the program to be listed in Set Default Programs.
EXAMPLE: Set Default Programs
NOTE: Notice the program (ex: Axialis IconWorkshop) now removed in the left screenshot without having to uninstall it.
OPTION ONE
To Backup and Remove a Program Listed in Default Programs
1. Open the Start Menu, then type
regedit in the search box and press Enter.
2. If prompted by UAC, click on
Yes (Windows 7) or
Continue (Vista).
3. In regedit, navigate to the location below. (see screenshot below)
HKEY_LOCAL_MACHINE\SOFTWARE\RegisteredApplications
![Default Programs - Remove a Listed Program-reg-1.jpg](https://www.sevenforums.com/attachments/tutorials/130010d1486581392t-default-programs-remove-listed-program-reg-1.jpg?s=4de99f16775b553476148fc5c56225ea)
4. To Backup the List of Programs in Default Programs
NOTE: It is highly recommended that you do this to backup your list of default programs so you will be able to restore any program(s) in OPTION TWO below that you delete.
A) In the left pane of regedit, right click on
RegisteredApplications, and click on
Export. (see screenshot above)
B) Type in a name (ex: Default_Programs-RegisteredApplications.reg), and save this to your Desktop. (see screenshot below)
C) Move this exported REG file to where you will like to keep it saved it. This will be your only backup of the listed programs in Default Programs before you delete any of them below.
5. In the right pane of
RegisteredApplications, right click on the program (ex: Axialis IconWorkshop) that you want removed from the list in
Default Programs and click on
Delete. (see screenshot below)
6. Click on
Yes to confirm the deletion. (see screenshot below)
7. Repeat steps 5 and 6 for any other program you want to be removed from the list in
Default Programs.
8. Close regedit when finished.
9. If open, close and reopen
Default Programs to see the change. (see example screenshots at top of tutorial)
OPTION TWO
To Restore Backup of Listed Programs in Default Programs
NOTE: You will only be able to do this if you did step 4 in OPTION ONE above.
1. Double click on the exported
REG file that you exported in step 4 of OPTION ONE above, and approve the merge when prompted.
2. If open, close and reopen
