Firefox - Enable Aero Glass Transparency
Page 3 of 14 FirstFirst 1234513 ... LastLast
  1. Posts : 141
    Dual Boot 7600 RTM x64
       #20
    Issue with window explore
    Ok , got as far as here, then got this error
    xxrazor
  2. Posts : 321
    Windows 7 Home Premium SP1 64-bit
       #21
    Hello xxrazor,
    Welcome to Seven Forums :)
    Do you have glasser installed ?
    Alternatively you could type %appdata%\Mozilla on your windows explorer and browse to your Firefox Profile and go to extensions folder > glasser@sixxgate.com > chrome
    EdRiK
  3. Posts : 141
       #22
    Alternatively you could type %appdata%\Mozilla and browse to your Firefox Profile () and go to extensions folder > glasser@sixxgate.com > content
    I have a pretty good idea what i am looking for, does the extension need to be enable for me to see it in the folder, i have it install, i can not find it..
    C:\Program file x86\Mozilla Firfox\extension\? can not see glasser
    xxrazor
  4. Posts : 321
       #23
    You have to go to the Roaming Mozilla folder not the folder where you installed Firefox :)
    to do that read my previous post :) Here's some screen shots
    to make things clearer
    After the second screenshot.. choose the Firefox folder
    EdRiK
  5. Posts : 141
       #24
    edrik said:
    Hello xxrazor,
    EdRiK
    Found it, will get back to you, thanks for the help
    xxrazor
  6. Posts : 321
       #25
    I'm glad to be of help :)
    -EdRiK.
  7. Posts : 141
       #26
    -EdRiK.
    Ok, As you can see , i am not quite there yet,
    In the first image you can see that i have the plugins required and enabled.
    I have placed Style here
    Now this is what i get when i place the Aero Fox7 Glassed text into the Style and preview.
    Not there yet.
    xxrazor
  8. Posts : 321
       #27
    This style works only on the default theme.. I'll look for a way to make it work with other themes too. My codes was for using all-in-one sidebar.. I could post the code for the default sidebar of firefox if you don't want to install all-in-one sidebar. :)
    EDIT
    I found a way to make glass work with other themes but I'm still trying to fix the sidebar at the moment :)
  9. Posts : 141
       #28
    EDIT
    Happy to wait if you are happy to help.
    xxrazor
  10. Posts : 321
       #29
    I managed to make the glass work with other themes but I'm not sure if it works with all Firefox themes, see Step 6: updated styles on my tutorial - here
    I hope this helps,
    EdRiK.
