Firefox - Enable Aero Glass Transparency
Page 5 of 14 FirstFirst ... 34567 ... LastLast
  1. Posts : 910
    Win 7
       #40
    The google page is black because you are on google.com.au you need to either change the style or use Google glass international style or the more updated version here
  2. Posts : 4,925
    Windows 7 Professional 64-bit
       #41
    or edit the script and add .au to all the google urls.
  3. Posts : 910
    Win 7
       #42
    Yes that is what i meant by change the style.
  4. Posts : 141
    Dual Boot 7600 RTM x64
       #43
    Thanks guys, still no luck, i think it some else conflicting with google style, i was going to load basic Firefox 3.5 into VM Ware, but Aero does not work in Vm Ware.
    So, here other pic
  5. Posts : 910
    Win 7
       #44
    You will need to add the domain to the whitelist in the "dwm-overlay.js" file as well.
  6. Posts : 141
       #45
    I think my google and sevenforum window problems are the same, not what that is yet, but i will work it out.
    thanks for the help
    xxrazor
  7. Posts : 910
    Win 7
       #46
    Clearly it is working on seven forums, if you have set the seven forms to windows 7 v2 b as well it could be a cookie issue not letting you change the style. If that is the case logging out and clearing your cookies for seven forums and logging back in will correct that.
  8. Posts : 141
       #47
    Well, here you go, i have managed to get the google web browser working, none of the sub address are working though, they are still Black, Mail, image, group, and video, etc. It's funny though, did have google mail front page glass up until now.
    xxrazor
  9. Posts : 910
    Win 7
       #48
    xxrazor
    When you use the whitelist you need to add every address that you want the glass to be applied.
  10. Posts : 141
       #49
    YupYup
    Can you give me an example of how the text should look in the white list for the other address, i have tried a few combinations without any luck.
    xxrazor
