Firefox - Enable Aero Glass Transparency
Page 6 of 14 FirstFirst ... 45678 ... LastLast
  1. Posts : 910
    Win 7
       #50
    xxrazor said:
    YupYup
    Can you give me an example of how the text should look in the white list for the other address, i have tried a few combinations without any luck.
    xxrazor
    I don't use the white list but i would imagine it would look like this
    var whiteListItem = new Array
    "www.google.com.au",
    "images.google.com.au",
    "video.google.com.au",
    "groups.google.com.au",
    "mail.google.com",
    "www.sevenforums.com"
    If not try adding http:// in front
  2. Posts : 141
    Dual Boot 7600 RTM x64
       #51
    "mail.google.com",
    Thanks mate, i have every google page working bar the gmail, email list, i have made a lot of changes with this one still no luck, almost the same problem i have with seven forum glass, got to work on that one still, deleted all the cookie as suggested no luck there either.
  3. Posts : 910
    Win 7
       #52
    Gmail is working as intended, the style is not complete yet. Have you checked if you can change the seven forums to other styles? if so it is not a cookie issue.
  4. Posts : 141
       #53
    I am not sure what you mean here
    "the style is not complete yet" do you mean for gmail, if so what should i change.
    And here
    "change the seven forums to other styles?" not sure when other style.
    Have to say this has come a long way, never say die.
    thanks
    xxrazor
  5. Posts : 910
    Win 7
       #54
    And here
    thanks
    xxrazor
    Yes the gmail style is not finished yet, i have not had a chance to even look at gmail yet so i can't say what needs to be changed. As for the seven forums scroll down to the bottom of the page there you will see a dropdown list to choose the style, it needs to be on "windows 7 v2 b" for it to work with the matching style in stylish.
  6. Posts : 141
       #55
    Got it style change at the bottom of the page made all the difference, I am interested in glassing a web page, can you point me in the right direction please.
    Well the only thing i have left to do is gmail, i am happy to lend any assistant you require to complete.
    I am going to work on Longhorn patch's for new verison of W7 now.
    Thanks for your help in this matter, i have learn't heaps.
    Thanks to the team, big thanks to YupYup
    xxrazor
  7. Posts : 4,925
    Windows 7 Professional 64-bit
       #56
    xxrazor said:
    Thanks guys, still no luck, i think it some else conflicting with google style, i was going to load basic Firefox 3.5 into VM Ware, but Aero does not work in Vm Ware.
    So, here other pic
    You see those url-prefix lines with google in it? You need to add .com.au to each one.
  8. Posts : 910
    Win 7
       #57
    Actually with the style pictured you don't need to add anything for it to work, the problem he had was adding the domains to the whitelist.
  9. Posts : 141
       #58
    Thanks swarfega, i have every google page working except> Gmail, my email page, the login is fine, but once you log in, all my email are white.
    Everything is good, i will keep trying with the last one untll i get it, never say die.
    xxrazor,
    Ps you guys rock
  10. Posts : 58
    Windows 7 Ultimate 7600 RTM - Windows Server 2008 R2 7600 RTM Dual Boot
       #59
    Ok I did everything but the glassser@sixxx folder isn't there
    Can you upload the folders from step 3 and 4 for me?
