#60
how can i modify the background of the google myself...any tutorial?
Hello G2gCya,
You could try modifying an existing google userstyle.css or create your own :)
However it is advisable that you use an existing style and mod it to your liking, using a style with comments would be much better. :)
Look for this inside the userstyle to change the background:
Code:background:{ <insert color or image URI here> }!important;
Hope this helps
-EdRiK.
Hey guys I got it. How do I make blank tabs glass?
